11-01-2014, 08:54 PM | #1 |
Sway bar bushing installation
I need to replace my sway bar bushings, and purchased Moog k6169, which are marked Ramco. They are black and I think a harder try rubber.
My question is should they be installed dry or lubed with a silicon based grease? |
11-01-2014, 09:04 PM | #2 |
Re: Sway bar bushing installation
Definitely lubed, otherwise they will squeak and be very annoying
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-01-2014, 09:06 PM | #3 |
Any recommendations for lube?
11-01-2014, 09:11 PM | #4 |
Mine came with a little thing of clear grease when I bought the bushings. I assume its a silicone lube.
11-01-2014, 09:27 PM | #5 |
I'd use dielectric tune-up grease (mine is made by Permatex). I've also seen it called silicone spark plug boot release.
11-05-2014, 10:13 PM | #6 |
Thanks for the advice.
Unfortunately when I removed the old ones I found out that the brakets were all bent. So I opted to go with the energy susspension kit, which included a tube of what I think is silicone based lube. |
