01-17-2020, 11:42 PM | #1 |
Ignition removal?
Hey guys so which is it pin in and turn clockwise or anti clockwise?
The text says turn counter clockwise but the picture has an arrow indicating clockwise? Just dont want to stuff anything up in the process |
01-17-2020, 11:48 PM | #2 |
Old member
Re: Ignition removal?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-18-2020, 01:23 AM | #3 | |
01-18-2020, 10:26 AM | #4 |
Old member
Yes! You don't have to remove anything to take the connector off the back. Just take a small screw driver and pry the 2 prongs out of the holes.
01-18-2020, 09:20 PM | #5 |
Something is loose on the back of mine ...does the front bezel tighten it up or the piece on the back?must be a bad connection somewhere sometimes it won’t start unless I wriggle the back of it around.
01-18-2020, 10:20 PM | #6 |
Old member
You can twist the barrel like Doc stated in the link but it want come completely apart unless the cylinder is removed. You need to take the plastic wire connector off and twist it back together then take the cylinder out like you want to begin with then twist it off.
01-18-2020, 11:21 PM | #7 |
Who Changed This?
You need a new ignition switch if you have to wiggle the key around. All the rest is just mechanical mounting hardware. The contacts inside the switch carry quite a bit of current, especially on the start circuit. If you can find it there in OZ, go ahead and replace the lock cylinder while you're at it. Having different keys for the door and ignition prevents people from using a slide hammer to remove a door lock cylinder and quickly duping a key and then driving your prize away. It's really just a delaying tactic, because if someone really wants your truck, they're going to get it. It is possible that the plug is the problem, but you can inspect that once you pop it off.
01-24-2020, 02:27 AM | #8 |
All sorted...... just need a fan switch resistor now
01-24-2020, 07:34 PM | #9 |
Those things can be a real PAIN when they are worn out. I had to spray WD40 inside my old one to get it to separate from the lock cylinder housing.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
