11-15-2020, 03:34 PM | #1 |
Old member
C-20 brakes with adjustable proportional valve
I have the Ramp truck front disc all done. Truck stops great but was wondering about the valve. Just wondering how it works. Should it be turned in to get more pressure and less flow are should it be turned out to get more flow and less pressure????
When we set it up there are 11 full turns from all the way out to full in. It's set at 9 turns in now from my notes I have. What is the knee effect that is always talked about? No it's not factory routed. I told him to do it as easy as he could. Master cylinder is front bowl is rear drums & back bowl is front disc. Lines run to adjustable proportional valve and the 2 front disc lines out to brakes and one line to rear drum's.
11-15-2020, 05:21 PM | #2 |
Re: C-20 brakes with adjustable proportional valve
Clockwise, increasing pressure will bias the brakes more to the rear relative to where you have it now. I adjust on a gravel road, applying the brakes fairly hard, keep applying pressure (increase on the knob) until the rear locks up too soon for you liking. You probably already know, but the adjustable portion of the valve only affects the rear brakes.
11-15-2020, 06:17 PM | #3 | |
Old member
Thanks for the info.
11-15-2020, 07:24 PM | #4 |
If they "just" lock on a gravel road, you really do not need to turn back. On pavement the rolling friction will be higher and should be just about set right. But the beauty is, you can fine tune very easily. I have a similar setup on a CJ7 and once I had it set, I never had to adjust it again.
Being a C-20, if you haul heavy from time to time, you can certainly apply more rear bias when you are heavy with just a 1/2 twist or so. |
11-15-2020, 07:44 PM | #5 |
Old member
Got it, thanks. Yea I don't haul much with it but I have before. I've carried light loads and heavy loads.
11-16-2020, 12:33 AM | #6 |
laying low
Andy may I suggest do your hard braking test in a wet parking lot? Wet roads are where you really don't want the rear end coming around on you while doing hard braking.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-16-2020, 10:31 AM | #7 | |
Old member
That's a good idea to!
11-16-2020, 08:32 PM | #8 |
Old member
I drove the truck several times it stops just fine but if I do decide to adjust them I will do it on gravel then try it out on a wet road also.
