02-27-2023, 08:09 PM | #1 |
driving is in my blood
Gen I small block heads, anything better then vortecs?
I know what your thinking, of course there are better heads! BUT, I'm looking at this from a stock or stockish cam perspective. Meaning, valve lift will be less then .500", less then .450" with the stock cam.
I've looked at flow charts, and I'm having a hard time finding comparable heads that flow more cfm at these low lift numbers. Over .500", lots of heads flow better. That's useless to me on my daily. Even the Etec 170's seem to be slightly less cfm below .500". I'm sure some AFR 227's might top the numbers slightly, but again those aren't useful for a mild 350. So, is there anything out there that I'm not finding? I'm looking for alternative castings for when I rebuild my 98's engine, vortecs are notorious for cracking and I'm over 200k miles so I'm just gonna assume they've cracked.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-27-2023, 08:32 PM | #2 |
Active Member
Re: Gen I small block heads, anything better then vortecs?
EngineQuest makes a nice replacement Vortec head, heavier casting than the factory. I have used them on a couple of small block builds and really like them.
02-28-2023, 07:03 AM | #3 |
Scoggin Dickey has some Vortecs too....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-28-2023, 11:55 AM | #4 |
LT4 Hot Cam and a set of Vortec heads is a very healthy and street mannered combo. If you could find some GM fast burn heads they would be sweet but for a stock style re-build any of the already mentioned replacements works, Jegs and Summit offer a "house" brand version as well.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
03-03-2023, 01:43 PM | #5 |
Those actually flow less in the lift range my stock cam runs.
03-06-2023, 01:09 PM | #6 |
Can you post a link to these vortec flow numbers? I am just curious.
-1971 K20 350/sm465 -2004 1500 |
03-06-2023, 03:28 PM | #7 |
Summit's basic iron heads are made by Dart, have good heart-shaped combustion chambers, 185cc intake runners, and flow between 230-245 out of the box.
Got a pair on my 350, they're way more than needed for a stocker, imho
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
03-07-2023, 11:16 AM | #8 |
There was an issue on cam lift limits, but that can be fixed with a cutting tool from Comp. I've not done it myself, but it looks straightforward.
I know you said you weren't interested in higher lifts for your daily, but fixing that when the heads are off would give you more options later.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
03-07-2023, 02:44 PM | #9 | |
03-07-2023, 07:54 PM | #10 | |
I've looked at flow charts from multiple sources over time, its not any one specific internet link.
