06-23-2021, 07:48 PM | #1 |
M&H Drag Radial Tire 315/60R15
I am looking at M&H Drag Radial Tire 315/60R15 for my 69 GMC stepside. I have a 2 inch lowering block. Anyone tried these for clearance?
Thanks Last edited by mikey531; 06-24-2021 at 05:49 AM. |
06-23-2021, 10:08 PM | #2 |
Re: M&H Drag Radial Tire 315/60R15
06-24-2021, 05:50 AM | #3 |
I forgot to mention I am also using a 1/2 inch spacer with longer studs so I can go to 4 /12 back space now.
The tire is 1.6 inch wider between the 315/60r15 and 275/60r15 so I think I can do it but it will be close. |
06-26-2021, 10:26 AM | #4 |
I'm paying attention to see what works
06-27-2021, 04:58 PM | #5 |
It's going to be tight. I have 275 55 17 on 15x9 with 5" backspace on mine and there is maybe 3/4" on either side. I am using a 71-72 5 lug axle. Mine is leaf spring and flipped for a 7" drop so you may have more wiggle room with only 2" block.
