05-18-2023, 02:46 AM | #1 |
Valve springs
As I slog through my Nova build. I am trying to figure out where I want to take things.
My new engine is a 1996 4.3 L99 or baby LT1, and I threw in a Corvette cam to liven it up a bit. I have the factory Corvette valve springs. Which have a tendency to float, but I also have some spring good to 560 lift. When the can has 460 lift. Is there such a thing as functionally to much valve spring, and there a rough starting point. |
05-18-2023, 03:52 PM | #2 | |
Re: Valve springs
05-18-2023, 05:56 PM | #3 |
Moderator
Re: Valve springs
The attached link will give you heaps of info on an L99 Little motor...
https://www.onallcylinders.com/2021/...8-gets-torque/
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-19-2023, 02:40 PM | #4 | |
Re: Valve springs
05-19-2023, 05:41 PM | #5 | |
Re: Valve springs
05-19-2023, 10:36 PM | #6 | |
Re: Valve springs
Also as stated I switched cams. Which can go start going into valve float with factory springs around 5500 if they want too. |
05-19-2023, 11:32 PM | #7 | |
Re: Valve springs
Maybe I just don't understand the goal of this project.. But this I do know.. The more an engine is modified in order to raise it's output, the less reliable it becomes.. Instead of building a 262 cu. in. peanut pusher of say 400 HP, that depends on high RPM to get around, why not build a 400 HP 383 (same physical size and approximate weight) that will make gobs of torque at a much lower RPM, and be much more reliable???? |
05-19-2023, 11:51 PM | #8 | |
Re: Valve springs
It is a DD engine, and I have a stash of LT1 parts already. So while it's apart I just added things I wanted that do not or will likely not have another home otherwise. It should be good for close too 270hp crank max. Which is a nice fun amount of hp. Combined with my 3.23 geared rear end, and eventual 2000 stall converter. It will meet all my need/wants for my DD. The Corvette cam is actually very mild, and they have no issues running 250,000 miles or more. If properly maintained. The B-body cam is really mild barely above the status of the generic flat tappets before it. The LT1 heads are where like the later LS the HP/tq come from. My 4.3 heads technically can support 425hp like the aluminum 350 LT1 heads, but I would have to spin around 7500 to get it. Where they can get there at 5000-5500 with a mild can swap. So adding a cam/spring combo I already own. Only will cost me if I add the springs other wise I will use then on my 350 I just built like they were bought for anyways. |
