Old 12-01-2021, 09:17 AM   #1
cherokeejohn
cherokeejohn's Avatar
94 Blazer K1500 T.B.I. 5.7 stalling issue
1994 K1500 Blazer, 5.7 T.B.I.,Auto. im att the end of my witts with this truck. It starts, idles, but if you give it any fuel, it stalls, if you put it in gear, it stalls. new dist., coil pack, ICM, fuel injectors, fuel filter, etc. I'm at my witts end and but ready to sell it and make it someone else's problem, but, its my 4WD, and up till now, has been my daily driver for the past 5 years. ant suggestions?
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 12-01-2021, 10:24 AM   #2
ky-donzi
Re: 94 Blazer K1500 T.B.I. 5.7 stalling issue
Throttle position sensor?
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 12-01-2021, 11:43 AM   #3
sntrym95
sntrym95's Avatar
Start by checking the temp sending unit on the intake manifold. If that's off, the ECM will not know how much fuel to send in. Specs are here:http://67-72chevytrucks.com/vboard/s...d.php?t=425788
TPS could be it but you'll need a scan tool to see the voltage.
Your best bet is to get a scan tool that you can see the data the ECM is seeing. Something is not sending the correct data to the ECM.
If all the electronic stuff checks out, your EGR valve may have failed: http://67-72chevytrucks.com/vboard/s...d.php?t=549711
Mike
sntrym95 is offline   Reply With Quote
Old 12-01-2021, 08:19 PM   #4
Just call me Sean
Just call me Sean's Avatar
You can use a regular voltmeter to check the TPS voltage, you just have to probe the wires. Did you check for codes?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
