08-18-2021, 11:55 AM | #1 |
0-80 Oil Pressure Gauges, Shift indicators
I have two shift indicators with cables. One cable is the type that takes a screw, the other type is the kind that just clips on. $35 shipped each. Please specify which one you need.
Two oil pressure gauges each from 1982 GMC diesel trucks. 0-80 PSI. $35 shipped each. Last edited by 66gmcguy; 09-16-2021 at 10:07 AM. |
09-16-2021, 10:07 AM | #2 |
Re: 0-80 Oil Pressure Gauges, Shift indicators
bump
10-10-2021, 09:46 PM | #3 |
Ill take the shift indicator that uses the screw & I'm going to assume that the 80 lb gauges are electric ( not mechanical ) so I would like one of those also if you still have both of these for sale.
Thanks Scott |
10-10-2021, 11:47 PM | #4 |
