12-13-2012, 09:34 PM | #1 |
Coupla wires that I don't know where to put.
Could anyone identify any of these wires? I believe the one with the white connecter in the first pic is for my distributor, but the other two wires were not hooked up before (I don't remember undoing them). The other one in the 1st pic looks like it should plug into a spade somewhere on the drivers side and the wire in the 2nd pic goes to the passenger side. All of my a/c wires are accounted for so I don't know what these are.
Mystery wire in 1st pick (I think) is green. Mystery wire in 2nd pic is blue.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
12-13-2012, 09:39 PM | #2 |
Watch out for your cornhole !
Re: Coupla wires that I don't know where to put.
First picture are the HEI wire and the oil pressure sending unit wire. Both are located very near each other on the back of the engine. If the HEI wire was truly never hooked up while you've owned the truck, it's probably a tach signal wire which plugs into the distributor cap directly next to the HEI power wire.
12-13-2012, 09:46 PM | #3 | |
12-13-2012, 10:23 PM | #4 |
It's possible your truck was switched to mechanical at some point as that looks like oil pressure to me also. I thought only 73-76 had mechanical but not sure.
1985 C10 2004 Avalanche |
12-13-2012, 10:37 PM | #5 |
Agree. I've been sitting here trying to figure out what else it could be, but that rubber shrouded wire is an oil pressure sending unit connection. I'm pretty sure of that.
12-13-2012, 10:41 PM | #6 |
Hmm, well considering some of the other things I've found on this truck it wouldn't surprise me if something was changed over during the last couple of owners. Any ideas on the wire in the second pic? It looks like some sort of fancy connector that would slide onto a spade as well. Thanks.
12-13-2012, 11:00 PM | #7 |
Possibly fast idle solenoid on the carb for air conditioning.
12-13-2012, 11:08 PM | #8 |
That makes sense. The 2bbl carb with the idle solenoid is long gone. Guess I don't need that wire anymore. Thanks.
12-13-2012, 11:17 PM | #9 |
Yup I agree.
12-13-2012, 11:50 PM | #10 | |
78K & 79C Jimmys
was idiot (in pic)now gauge
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-14-2012, 12:32 AM | #11 | |
I agree, that black rubber boot type connector is definitely for an oil pressure switch. So it's still possible that it's been converted over from warning lights to gauges. Another possibility would be that the factory used the same engine harness for trucks with & without factory gauges and just left that oil pressure wire unused on the trucks with gauges. If I get a chance tomorrow, I'll go check my 77 (with factory gauges) and see if it has an unused oil pressure light switch wire/plug in there. I could see them doing this for 76-up because these years used voltmeters so there wouldn't be any ammeter wiring necessary. And the same temp switch/sender wire could be used for either a light or gauge signal. |
12-14-2012, 09:09 AM | #12 |
That blue with boot connection is for oil pressure sending unit. My 76 is all original with the mech gauge but mine too has that connection that is unused. GM didnt make a diff engine harness for that, however there will be no power to it since it wont be connected via the overlay on the gauge assembly....I have checked mine....just let it hang behind engine.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
12-14-2012, 06:27 PM | #13 | ||
One thing I did find interesting to note is that the 77 gauge clusters (at least the 4x4 ones anyway) do have an "OIL" light at the bottom of the speedometer right next to the 4 wheel drive light. On the spare 77 cluster I checked, it even had a bulb in there and has traces on the printed circuit leading back to the cluster connector (same pin as the oil light on a non-gauge cluster). And if I'm reading the 77 wiring diagram correctly, it looks like it might already be wired up to that unused blue wire/plug behind the engine. Looks like I could add a Tee fitting, pressure switch, plug the wire in, and end up with both a gauge & an oil light. Last edited by ray_mcavoy; 12-14-2012 at 06:35 PM. |
12-14-2012, 10:15 PM | #14 | |
12-15-2012, 08:23 AM | #15 | |
12-15-2012, 09:30 AM | #16 | |
12-16-2012, 04:01 PM | #17 |
Ya not saying it came like that from factory, just remember something like that in the back of my mind. Was probably owner added at one point
12-16-2012, 05:26 PM | #18 |
78K & 79C Jimmys
found the pics after
in the 78 Jimmy I used an elbow,to fit the gauge sender
12-16-2012, 07:57 PM | #19 | |||
Although my 77 GMC doesn't have an electric choke, the wiring diagrams show that some 77 engines did come with them from the factory. And the wiring diagrams show it making use of that dark blue "oil light" wire along with an additional orange or brown/white wire (depending on the engine). Both wires lead to a 2-terminal oil pressure switch and a single light blue wire (hooked to the same terminal as the dark blue wire) runs from there to the electric choke heater. It looks like that orange or brown/white wire is the actual power feed wire and the dark blue one is still just for an indicator light. Although I'm guessing those trucks got a slightly different instrument cluster with a lens over the bulb reading "choke" instead of "oil". |
12-22-2012, 08:30 PM | #20 | |
Here's a pic of the back of a spare 77 gauge cluster showing how that dark blue wire is connected to the circuit traces: |
