Old 09-14-2014, 11:17 AM   #1
Orangetonicclicc
Orangetonicclicc's Avatar
Carpet or upholstery to replace area where gas tank once was
Can any of you guys direct me to a vendor that sells molded carpet in the area where the gas tank once was I moved my tank to the back.
Orangetonicclicc is offline   Reply With Quote
Old 09-14-2014, 11:33 AM   #2
Wizo
Wizo's Avatar
Re: Carpet or upholstery to replace area where gas tank once was
the floor or the back of the cab?
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 09-14-2014, 12:28 PM   #3
Grumpy old man
Grumpy old man's Avatar
Google flexformcarpet it is a non backed carpet made to flex and form to uneven shapes it comes in 40 and 80 inches wide and a number of different colors it should work for what your describing .Varies in price from $11.80 to $28.00 depending on color and width ,You can install it with spray can contact cement ...
Old 09-14-2014, 12:33 PM   #4
Orangetonicclicc
The back of the cab, where the gas tank was originally.
Old 09-14-2014, 12:34 PM   #5
Orangetonicclicc
Thanks Grumpy!
Old 09-14-2014, 02:37 PM   #6
Wizo
Wizo's Avatar
I'm gonna either get a thin piece of wood panel , spray on glue, and put on sub woofer box covering and screw in place or put the covering on the sound deadener covering and then directly on the sheet metal with spray on glue. Hope this helps. Show pix when ya get'er done.
Old 09-14-2014, 02:48 PM   #7
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
We sell a back wall curtain for when the tank is removed.. Made by trim parts carpet.
Kyle
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-14-2014, 03:01 PM   #8
Orangetonicclicc
Kyle
Do you have a picture Kyle?
Old 09-14-2014, 05:55 PM   #9
Andy4639
Old member
Andy4639's Avatar
Question Re: Carpet or upholstery to replace area where gas tank once was
I got to ask. If you removed the tank are you going to put a sound system in the truck? If so build the box to cover the back wall. I covered mine with sound deadner then built the sub box. I bought the carpet stuff at O Reilly's.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-14-2017, 09:49 AM   #10
el_fantasma
el_fantasma's Avatar
Kyle
Kyle, are you still around, you haven't posted in awhile. Do you have details of this product?
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
