Old 09-15-2020, 08:29 PM   #1
tinman_local2
Rockwell T221 mounting adapter seals
Anyone have a part number for the two seals in the adapter that goes between the sm465 and Rockwell t221 transfer case. Local parts stores are having trouble getting me the right seals. The dimensions are 2.62" OD, 1.875" ID for both seals, but the one on the trans side is 1/2" wide and the other is like 5/16" wide.
tinman_local2 is offline   Reply With Quote
Old 09-15-2020, 08:40 PM   #2
gmc684x4
Re: Rockwell T221 mounting adapter seals
It is sm420 and the Rockwell t221 tcase not a sm465
I do not recall the seal part numbers as it was in the early 90s i had mine apart last i do love the little bit extra low gear you get out of this pair over the 465 205 combo
gmc684x4 is offline   Reply With Quote
Old 09-15-2020, 09:11 PM   #3
tinman_local2
I stand corrected on the trans number. SM 420 trans.
Old 09-15-2020, 09:36 PM   #4
palallin
Hold the phone! The T-221 was most certainly mated with the SM465 in '69.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-15-2020, 09:44 PM   #5
gmc684x4
I have had 4 69 trucks they all had a sm420 with t221 tcase only trucks i seen with sm465 and a np205 tcase are 70 and newer or trucks that had been converted
One easy tell tail is sm420 front driveshafts is it has only 2 u joints
Where the sm465 setups have 3 u joints two make up a cardan joint
https://www.rockauto.com/en/catalog/...haft+seal,8416
Old 09-15-2020, 10:11 PM   #6
tinman_local2
Mine has 3 u joints for the front shaft. Either way I'm looking for the seal numbers for the adapter mount. Pretty sure it's a sm465.
Old 09-15-2020, 11:24 PM   #7
Hotcorner
Hotcorner's Avatar
Correct. And I have the seal # for the adapter.
http://67-72chevytrucks.com/vboard/s...d.php?t=796874
1969 GMC K25
WANTED TO BUY: dark green 69-72 steering wheel
2007 Chevy 2500HD Classic Duramax
Hotcorner is offline   Reply With Quote
Old 09-15-2020, 11:28 PM   #8
Hotcorner
Hotcorner's Avatar
. I used the same seal on both ends. See above. Worked fine and does not leak.
1969 GMC K25
Old 09-16-2020, 03:39 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
GM did produce trucks with an SM465/Rockwell T221 transmission/transfer case in Model Year 1968. They may have also gone into MY '69 on GMCs and Canadian trucks.
I know there is such an animal, I have one as a core.
Old 09-16-2020, 07:53 AM   #10
tinman_local2
Hotcorner that seal is for a 2" shaft size. My coupler is 1.875". Do you recall what OD your coupler is?
Old 09-16-2020, 09:15 AM   #11
Hotcorner
Hotcorner's Avatar
Interesting. My buddy and I both have 69 GMC K25s. Both had SM465/T-221 combo.
Ill measure the coupler. I have an extra one in the garage.
1969 GMC K25
Old 09-16-2020, 09:19 AM   #12
palallin
Don't have a pic of the SPID handy, but both the SM465 and the T221 are on it: '69 Chevy K-10.
Old 09-16-2020, 07:43 PM   #13
tinman_local2
The seal part number for the transfer case mounting adapter are SKF brand 18581. It requires two seals. The number for the drive shaft seals on the transfer case are SKF 17387 or National 472164. Also requires two. Hope this helps someone in the future. All parts books or parts stores will tell you different. These are the numbers that cross reference to the seals that I removed. The measurements for the seals are 2.625" OD, 1.875" ID. The width really doesn't matter for this application.
Old 09-16-2020, 09:09 PM   #14
Hotcorner
Hotcorner's Avatar
The OD for my sleeve is 2”.
1969 GMC K25
Old 09-17-2020, 07:46 AM   #15
tinman_local2
Originally Posted by Hotcorner View Post
The OD for my sleeve is 2.
Mine is 1 7/8". I wonder why the difference.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
