Old 11-27-2018, 01:31 AM   #26
Stormin08
Stormin08's Avatar
Re: Blueprint vs ATK Engines
i set mine up like this,
Edelbrock RPM Air Gap
MSD HEI street fire distributor
FItech 600 hp easy street
Summit brand 304 ss short headers into a JBA 304 ss Y pipe
March 2 belt Sport Track billet brackets
Air cleaber is to be determined, i have the edelbrock with the flow through top...but debating a closed factory look, modded to dual snorkel
Stormin08 is offline   Reply With Quote
Old 11-27-2018, 09:39 AM   #27
68Gold/white
Thanks all for correcting my lack of effort on what goes out the door at BP engines.
I've been looking at big block engineson their website, everyone has a "Blueprint" cast into the block at the top near where the intake sets.
Stormin, what are your plans for crank case ventilation???
68Gold/white is offline   Reply With Quote
Old 11-27-2018, 03:00 PM   #28
The Rocknrod
Moderator
The Rocknrod's Avatar
Well I called and got a recording I guess they dont answer e-mails.
You know what? I think I will just wait and save for the Chevy Performance SP350 357HP Crate Engine 19367080. They're in Texas anyway.
Old 11-27-2018, 03:15 PM   #29
jeffahart
jeffahart's Avatar
Nice, thanks!
j
White K20
jeffahart is offline   Reply With Quote
Old 11-27-2018, 07:48 PM   #30
Stormin08
Stormin08's Avatar
i have a cast aluminum angled breather similar to the link, it is painted black and will mount on the outside of the pass valve cover right between the bolts.
https://www.speedwaymotors.com/Garag...her,93825.html
Old 11-27-2018, 11:37 PM   #31
Captainfab
60-66 Nut
That will let air in, but you need a place to connect a PCV valve on the other side of the engine.
Old 11-28-2018, 01:13 AM   #32
Stormin08
Stormin08's Avatar
i am debating running check valves down into the exhaust...venting from the rear of the valve covers. otherwise, a bung will be added to the driver side.
Old 11-28-2018, 09:29 AM   #33
68Gold/white
I have wondered about doing such, although have no real intentions. I just like the clean look of the 67 and earlier scripted valve covers.
I've also thought about running one on the other side and running a PCV from it.
THe breathers I have looked at are on www.mooneyesusa.com, under auto accessories.
Old 11-28-2018, 07:54 PM   #34
Stormin08
Stormin08's Avatar
mine is a cast finish (easier to paint) with the finned top...but has a hidden set screw. i have it wrapped up and in the box still, i will check on the name.
Old 05-24-2019, 05:39 PM   #35
Rickysnickers
Bringing this back from the dead. Rocknrod, what did you ever decide as far as the engine goes?
Old 05-25-2019, 06:07 PM   #36
The Rocknrod
Moderator
My plan is to go with the Blueprint engine. I'm in Iowa right now working to get money to finish this truck the way I want.
I was just looking further into this when i saw this thread. Yes the Blueprint engine.
Old 05-29-2019, 01:14 PM   #37
Stormin08
Stormin08's Avatar
i just made 2 trips around the block on memorial day...i ended up drilling my driver valve cover near the rear and adding a stock style pcv for now.
i may run the mewagner dual stage pcv in the near future.
Old 01-12-2020, 09:02 AM   #38
The Rocknrod
Moderator
Originally Posted by Captainfab View Post
While a cam with a 112LSA will produce better/more vacuum than a cam with a 110LSA, I don't know if it will be enough difference to affect the operation of vacuum assisted brakes. Do you have a dual diaphram brake booster Rod? Ask the people at Blueprint and see what they say about the proposed idle vacuum.
The LSA for the GM 350/357 is 108.
Old 01-12-2020, 10:05 PM   #39
Captainfab
60-66 Nut
I didn't realize that. That engine should have a nice choppy/lopey idle but also a little low on vacuum.
Old 01-13-2020, 08:59 AM   #40
The Rocknrod
Moderator
Ya it was hard to nail down the real number, for the first couple years the numbers were all over depending on where you read it. I found it using the part number for the cam in that engine.
Old 01-14-2020, 06:11 PM   #41
Tom
driving is in my blood
Tom's Avatar
The LSA is slightly tight but the duration is mild he'll be fine with brakes IMO.
Old 01-14-2020, 06:15 PM   #42
The Rocknrod
Moderator
On the GM engine?
Old 10-07-2021, 12:50 PM   #43
forestb
forestb's Avatar
Which engine did you end up getting. Were you happy with your choice?
forestb is offline   Reply With Quote
Old 10-07-2021, 04:34 PM   #44
The Rocknrod
Moderator
Me?
Old 10-07-2021, 04:44 PM   #45
forestb
forestb's Avatar
Originally Posted by The Rocknrod View Post
Me?
yep
Old 10-07-2021, 05:05 PM   #46
The Rocknrod
Moderator
Originally Posted by forestb View Post
yep
I went with the Blueprint 350/385. Vortec head, 1 peice rear main seal, roller cam & lifters. They have great proceedures to pre startup and I have had zero issues with it. Better quality than I expected for the price.
Old 10-15-2021, 03:53 PM   #47
The Rocknrod
Moderator
I just watched this video (plant tour and assembly) - https://youtu.be/Jzr2U8bGpvc
They talk about making they're own blocks, but I bought a seasons block.
