03-06-2021, 01:46 AM | #1 |
Front Sway Bar question
G’day all,
I have a sway bar question. I picked up a front and rear sway bar kit from POL for my 60 GMC. And of course parts don’t quite bolt right up as implied. 1960 must be an odd year for resto mod parts. Anyway, if I mount the end links as per the instructions the bolt heads are about ½” to ¾” from contacting the tie rods. (see pic 1&2)If I turn the wheel either way or lift the front of truck they actually hit. If I flip the end link bracket 180 deg. (see pic 3) I have lots of clearance but now the lower bushing is below control arm, about 8” off the deck. Is this going to be an issue? I’m worried if I scalp a groundhog or roll thru a pothole I may tweak the end link or damage something more. Any suggestions would be appreciated. The rear sway bar needed some mods as well. I will drop those in another post. Hope I submitted this right, not very good with PC's |
03-06-2021, 11:43 AM | #2 |
Re: Front Sway Bar question
This may be a dumb suggestion, but here it goes. In the first photo (going from left to right), you have two rubber cushions between the sway bar and the bracket. What would happen if you were to just take out one of the cushions and just use one in this spot? I know the bolt might be a little long. You could use a shorter bolt if you chose to go that route.
03-06-2021, 07:49 PM | #3 |
I thought of that as well. I could use a shorter bolt and one less bushing. But, my concern would be : Do I have enough movement in the end link to not cause a bind during movement and possibly bend or break the bolt. Figured I would ask if any others had this problem and or a solution. Thanks for your input.
03-06-2021, 11:07 PM | #4 |
60-66 Nut
Most of the aftermarket parts suppliers do not know that the '60-'62 frames and suspensions are not the same as the '63-'72's. That is why many market their parts as fitting '60-'66 or '60-'72. To my knowledge, on one makes a sway bar specifically for the '60-'62's. There was a forum member working on producing them, but I have not seen him on here in a while.
03-06-2021, 11:42 PM | #5 | |
With regular inspection, you'll know if it's bending the bolt. It's just a hardware store grade bolt that you need, so if it bends you can either replace it or but a bushing back in. Or half a bushing, even. Or a varying stack of washers.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
03-07-2021, 12:13 AM | #6 |
Thanks all, I have found many things dont quite fit as they claim but thats why the resto mod term fits, lol. I will try shortening the bolt useing a grade 5 and try it out when i get it back on the road. Just finished all the brakes and drums. Have yet to install new master and booster and swap timing gear for a chain.Thanks again
03-07-2021, 06:18 PM | #7 |
BLAZER THIRTY!!
I'm gonna be ordering mine very soon from POL for my 62 ,from your pictures it looks like you have a extra rubber bushing in it as well as long bolt ? , the kit is.new and says 60-62 so I'll be watching this one for my truck
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
03-07-2021, 07:42 PM | #8 |
So far I am happy with the install. We will see how it is once I get her back on the road, I have a few more things to do. I got the rear sway bar kit from POL as well. Had to do some mods to fit it right. I had to fab up two retrofit plates to the trailing arms so the rear bushings would mount to the trailing arms since they come back on an angle. We shall see how that works out.
03-07-2021, 08:57 PM | #9 |
That's what it's all about right there! Adapt an overcome!
03-07-2021, 09:09 PM | #10 |
Semper Fi
03-07-2021, 10:27 PM | #11 |
As Marines we were taught to adapt and over come. Well done Devil Dog !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
03-07-2021, 11:47 PM | #12 |
OoooRah!!!
03-08-2021, 03:36 PM | #13 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
03-08-2021, 06:24 PM | #14 |
The upper bracket that the end links bolt to are forward of the rear axle on the truck frame. If you need a better pic I can snap one later this evening when I get home. Let me know
03-08-2021, 08:03 PM | #15 |
Here are some more pics for the rear sway bar. Hope this helps some
03-09-2021, 03:32 PM | #16 |
Crystal Clear! How does your truck handle now? Thinking of doing the same thing to my 60. Thanx
03-09-2021, 05:03 PM | #17 | |
03-10-2021, 08:17 AM | #18 |
Have not tested on the road yet. Still doing some other updates. Currently replacing the Timing gear with a double roller chain. Gear was way too noisy for me. Sounded like a poor mans Turbo, Let ya all know when she's back together.
