05-16-2022, 11:10 PM | #926 |
Re: SkinnyG's '61 Apache
I wasn't happy.
Also, went for a walk today, first time after 5 days of covid. Wow. Winded real fast. I should have expected that, but I was surprised.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-16-2022, 11:36 PM | #927 |
Glad to hear both of y'all are doing better
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-21-2022, 10:48 PM | #928 |
I feel like I've been here before:
05-22-2022, 11:16 PM | #929 |
And here, like a week ago:
And widened the brake pedal twice because I can't measure:
05-23-2022, 08:24 PM | #930 |
In an impulsive move, I decided to spray the underside of the hood engine bay colour instead of body colour.
And to feel productive, I hung the doors. Different camera, which captures the orange better:
05-24-2022, 01:44 AM | #931 |
It'll be nice, do you paint the doors in the cab?
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
05-24-2022, 10:26 AM | #932 |
The gray was previously painted on the doors. The orange will be painted on the doors along with the whole truck all in one go.
05-29-2022, 12:58 AM | #933 |
Blasted and epoxy primed the hood hinges,
and took a blurry picture of the plugged antenna hole.
05-30-2022, 01:07 AM | #934 |
Painted the hood hinges and the heater duct/valve/thingie:
Also picked up two sets of LS injectors on the weekend (50% off sale at Pick-N-Pull) which I will decap and get cleaned and flow tested.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 05-30-2022 at 01:15 AM. |
06-01-2022, 10:29 AM | #935 |
Pops came home from the hospital last night. 25 days stay. Home care started that very evening too (yay). He seems to have aged considerably since before he went in. We'll see how he is once he gets some strength up along with consistently taking his meds.
Got the rubbers seals on the inner fenders on Monday, and might be installing those tonight.
06-01-2022, 11:18 AM | #936 |
Good news about your Pops. Praying for his full recovery.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
06-02-2022, 12:27 AM | #937 |
Blasted some fasteners in the cabinet:
06-02-2022, 10:05 AM | #938 |
Gotta love fresh, consistent hardware!
06-04-2022, 11:39 PM | #939 |
Dad's back in hospital.
Primed a set of my 18" steelies, and the cowl outers, and the fasteners: Also picked up a Fuel Injector Cleaner/Tester and have been playing with that, and twenty-four Chevy LS injectors:
06-07-2022, 11:56 PM | #940 |
Faux white-walls (photo saturation changed to better portray the actual orange):
06-08-2022, 01:28 PM | #941 |
So how much are you charging for injector cleaning and flow test?
Those wheels look awesome! |
06-08-2022, 02:58 PM | #942 |
Wheels look fantastic.
Hope your Dad is making progress. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
06-08-2022, 09:59 PM | #943 | |
Local guy has a proper ASNU machine, and charges $30 per injector, which I believe includes new seals and filter.
06-08-2022, 11:11 PM | #944 |
Dad's home again. Looking a bit better than when he last came home. We'll see.
06-09-2022, 07:00 AM | #945 | |
P.
06-09-2022, 11:27 AM | #946 |
Yes, me too
06-09-2022, 11:37 AM | #947 |
Absolutely echo what Paul says.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
06-12-2022, 08:03 PM | #948 |
You know what is hard to install all by yourself? The Hood. The hood is hard.
Use some "studs" (long bolts with the head cut off) to use as a "pin" to keep the rear hood mount hole in the hinge, while you fumble to get the front bolt in. Then unthread the "pin" and thread in the rear bolt. All the while balancing the hood on your back/shoulders/head.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 06-12-2022 at 09:22 PM. |
06-13-2022, 01:58 AM | #949 |
I'm also a bit afraid of having to work on my hood and then install it. But you found a good solution.
06-16-2022, 07:05 PM | #950 |
Met with pop's case manager today. Some new at-home assessment since he's come home from the hospital. They've begun paperwork to get pops in a home. Freaking yay!! Such a relief.
