Old 01-10-2023, 04:38 PM   #1
70C10Ginger
70C10Ginger's Avatar
Help sourcing wiring parts
Hey all! I’ve got a 70 GMC K25 I’ve been trying to restore. I’ve rebuilt a 350, np205, etc. almost all the mechanicals are sound (damn “new” steering box leaked right out of the box), and am now trying to prevent the thing from catching on fire while running down the street cause of the wiring.
I have some parts already fingered out, and am trying to get it all assembled. Driving on the interstate during a rainstorm at night with the stomper switch glowing and barely any headlights was not a fun experience.
I’ve got a fuse block, firewall connecter, and engine bay harness. All the wiring from the engine bay to the tail lights has been done by an older friend of mine, and I’m trying to build the firewall connector, fuse block out to all the connectors: I have a kit from speedway for the fuse block rebuild, but can find the firewall connectors. Here’s some pics.
I’m trying to completely replace all of the wiring components and upgrade it. Trying to have a dual battery setup with an ARB air compressor and a power tool charging station.
70C10Ginger is offline   Reply With Quote
Old 01-10-2023, 04:58 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Help sourcing wiring parts
I used M&H. They can reproduce the stock wiring harness perfectly. All the lines are color coded correctly and the terminals are Factory. Not cheap. But the best.
Old 01-10-2023, 05:51 PM   #3
70C10Ginger
Ha, major trust issues, so I’m laying every square inch of wire personally. Wondering if anybody has done this before. Here are those pics I promised. This is of the block and firewall blocks with the connectors
Old 01-10-2023, 05:57 PM   #4
70C10Ginger
Attention
Only looking for part number for firewall connectors and wire info. Not that you bought some kit from whoever.
Thanks for all the knowledge
Old 01-10-2023, 07:34 PM   #5
HO455
HO455's Avatar
NAPA carries the Packard 56 connector pins you need. I'm not listing the part numbers as they come in different sizes depending on the wire guage used.
The most of the connector bodies can be purchased individually from M&H. They don't list them on their web site, you will have to pick up the phone and call them.
RIP Bob Parks.
Old 01-10-2023, 08:16 PM   #6
Old_Truck_Fan
American Autowire has the Packard terminals and connectors available individually. They have good tech support too.
https://www.americanautowire.com/sho...als-connectors
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 01-10-2023, 09:56 PM   #7
70C10Ginger
So they are called packard terminals? What are the ones that go into the connection for the dome light? Thank you all so much
Old 01-10-2023, 09:57 PM   #8
70C10Ginger
Never mind. This has everything! You are so awesome. Thank you
Old 01-13-2023, 12:14 AM   #9
franken
Make sure there's a fusible link between the battery + side and the little fender junction block to keep a short from cooking the harness between the battery and fuse panel...
fuse box fix, fuse panel, wiring harness, wiring help
