10-26-2009, 11:51 AM | #1 |
60/40's with belts
I found some seats at the junk yard this weekend and deciced to get them, and some seatbelts, wish the belts were blue, oh well.
10-26-2009, 01:23 PM | #2 |
Re: 60/40's with belts
That looks good in there. I had the same in my 70 (I went full bench now) and the belts. They are a great and very comfortable combo!!
10-26-2009, 01:40 PM | #3 |
How did you do the upper seatbelt mount?
www.vancerutherford.com |
10-26-2009, 02:47 PM | #4 |
Those look nice in there. If only there was a way to cover the plastic at the bottom.
10-26-2009, 02:54 PM | #5 |
...just another truck junkie..
Looks pretty good. What were the seats out of?
Mike "Bear" Shea |
10-26-2009, 03:12 PM | #6 |
1) Seats are out of a 88 extended cab.
2) I just drilled a 1/2" hole and used a backer plate for the upper seatbelt bracket. 3) On the bottom of the seat is the steel support, not plastic, and I can come up with a cover to close the hole if needed. Thanks Guys |
10-27-2009, 12:09 AM | #7 |
60-66 Nut
Those look good. Those '88 and up seats are pretty comfy.
10-27-2009, 10:10 AM | #8 |
Yea, they feel good
10-27-2009, 02:18 PM | #9 |
Could you elaborate some more on the shoulder belt mount near the door frame? How did you get a backer plate behind the interior sheetmetal? I've been wanting to do this on my '66, but have yet to figure it out, other than cutting and welding.
Members i've met: LiLRed66 |
10-27-2009, 08:58 PM | #10 |
I used a 7/16" bolt, put the bolt thru the seatbelt bracket, put a nut on just tight enough to let the bracket swing loose, then a flat washer. put that assemble thru the drilled hole, reached up the inside wall, added a backer plate, flat washer, lock washer, and nut.
Will this be strong enough in an acident, only one way too tell, and I dont plan on finding out. |
10-28-2009, 09:27 AM | #11 |
Thanks. That makes sense. I thought the attachment point was a lot farther up in the corner and just couldn't figure out how you got it there. Now i need to find some seats.
10-28-2009, 10:34 AM | #12 |
Im 5'-11", and I went 3'-0" from the floor and I could just reach where I needed to. If you are taller you might want to go alittle higher.
