06-10-2021, 12:58 PM | #1 |
Tire & wheel size
I have 69 C10 swb . Lowered 2 1/2 front, 4 in rear. Im thinking about 18’s or 20s. Would love to see pics of some that are lowered similar with wheel & tire size and backset. Thank you
Posted via Mobile Device |
06-10-2021, 05:05 PM | #2 |
Re: Tire & wheel size
When you get new wheels - be sure you have the proper Back Spacing or else you might hit the Lower Control Arm when you turn.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-10-2021, 11:55 PM | #3 |
06-11-2021, 01:00 AM | #4 |
Here is a picture of 20" on a SWB 1970.
Back spacing is zero. fronts are 8.5" and the rears are 10" Rick |
06-11-2021, 07:52 AM | #5 |
I had to go from 15x8's to 15x7's on the front with a 3" BS ... but I have read some drop spindles have adjustmets designed in them so one doesnt need to change BS. My 15x8's had a 4: BS.
Hopefully others will chime in.
06-11-2021, 10:57 PM | #6 | |
06-13-2021, 06:19 PM | #7 |
Zero offset works best. That is where the mounting flange for the wheel is in the very center of the rim. 15" wheels can be a challenge. I have 17x8 on the front of mine with 4.5" back spacing (wheel width is measured between the tire sealing surfaces or "between the beads" so a 17x8 inch rim is 9" wide outside to outside, so 4.5" in from the back is exactly 1/2 way to the front, so it is not offset at all). I have 235 55 17 tires mounted. In the rear I run a 17x9 once again zero offset, so 5" back space with 275 55 17 tires. My '69 has a '71 5 lug axle swapped in and my truck is a stepside on leaf springs. All of those things have to be in alignment for that tire to work on a stepper. You have much more space in the rear on a fleetside truck as well as if you have coils.
06-14-2021, 12:51 PM | #8 |
Hey Mike C do you have any photos you can post?
06-15-2021, 08:59 AM | #9 |
Here you go.
06-15-2021, 11:52 AM | #10 |
Nice stance and tire size.
06-29-2021, 06:41 AM | #11 |
06-29-2021, 10:30 AM | #12 |
4 1/2" in the front with 2" springs and 2 1/2" spindle. Leaf spring flip in the rear for 7" drop.
