09-29-2022, 12:07 AM | #1 |
383 and roller cam for 78 c10
So I just bought a Smedling performance 383, and I have 72cc Summit heads and 67cc Summit Vortec heads. Looking for cam recommendations for my 1978 c10. I have a LT1 from a 1995 Camaro (705), AND A 94666492 Chevrolet cam for a Mercruiser. I also have a L31 cam. Which would you put in?
383, th350, 28 inch tall tires going with 3.23 with lsd. Probably a 1700 stall converter. looking for Torque 2500-4000rpm |
09-29-2022, 03:19 AM | #2 |
Re: 383 and roller cam for 78 c10
The Merceuiser cam from the specs I found would be a stronger performer at some rpm.
The L31 cam is nothing special, but would be a good driver. So I would go with the 705 cam. It would be a great driver, and should get you around 350hp with some 400tq. |
09-29-2022, 09:13 AM | #3 |
That was the one I was thinking of going with as it will have a decent idle, and will give all around performance.
09-30-2022, 08:56 PM | #4 |
If you want a smooth idle you can't beat the L31 cam and vortec heads. I have the L31-R crate motor in my C10 and it's the smoothest idling 350 I ever owned. It still has good power with a lot of low end torque. If you want hp go with the LT1 cam and vortecs.
10-04-2022, 05:49 PM | #5 |
driving is in my blood
No idea what the specs are for that marine cam but the oem vortec cam is so puny I can't believe anyone would put one in something that didn't already come with it in there. Lt1 cam all the way. Its still very small.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-04-2022, 10:01 PM | #6 | |
Basic Operating RPM Range: 2,000-5,500 Intake Duration at 050 inch Lift: 214 Exhaust Duration at 050 inch Lift: 220 Duration at 050 inch Lift: 214 int./220 exh. Advertised Intake Duration: 270 Advertised Exhaust Duration: 276 Advertised Duration: 270 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.452 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in. Valve Lift with Factory Rocker Arm Ratio: 0.452 int./0.465 exh. lift Lobe Separation (degrees): 112 |
10-05-2022, 10:41 AM | #7 |
I would definitely go with the Vortec heads assuming this engine has the dished piston that returns 9.8:1 compression with 65cc chambered heads. Given the relatively low static compression ratio, you will want to keep your dynamic compression ratio up by using a cam with reduced overlap, in my opinion. I think, given this combination, I would go with the Mercruiser cam. Should be a torque monster!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
Thread Tools | |
Display Modes | |
