Old 09-23-2002, 12:29 PM   #1
useRc10
useRc10's Avatar
Question gears q?
i was thinking of changing the gears on my truck but i dont really know what to get and everything...its a '72 chevy lwb 350 with 3 spd manual...
what gear ratio would you recommend? where is a good place to get them? how much is a good price? what all is involved in cahnging them over?
i dont know what i have now but i know its not posi cause i'm only spinning 1 tire...thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 09-23-2002, 01:21 PM   #2
Michael A. K. G
A worn out Posi behaves EXACTLY like an open diff. You just have to replace the clutch packs. That's much cheaper (and considerably easier in many cases) than swapping in a Posi diff.
The most reliable way to tell if you have a Posi or not is to remove the diff cover and see if you can find a preload spring in the center of the diff.
Clutch-type Posis don't last forever. On a 30+ year old truck it is quite likely to be dead.
There are other types of Posis, but the clutch ones are common.
Michael A. K. G is offline   Reply With Quote
Old 09-23-2002, 01:24 PM   #3
useRc10
useRc10's Avatar
how do i tell what gears i have by counting teeth?
maybe eventually i'll get around to pulling the diff. cover but being at school only gives me a little bit of time to work on it on the weekend...thanks
AIM: Auntjoedadda
Old 09-23-2002, 01:31 PM   #4
Michael A. K. G
The gear ratio is the number of ring gear teeth divided by the number of pinion gear teeth. For instance, my Ford 7.5 has 41 ring gear teeth and 11 pinion teeth, for a gear ratio of 3.73.
For the ring gear, it helps to mark the starting point with liquid paper (on the side of the gear, not on the teeth), so you know where to stop. Dried liquid paper comes right off with brake system cleaner.
You can get an approximate count for an OPEN diff by lifting one wheel and putting the tranny in neutral. The gear ratio is the number of driveshaft turns per wheel turn MULTIPLIED BY TWO. For a working Posi diff, you lift BOTH wheels and forget about the factor of two.
You will have to count driveshaft turns down to 1/8 turn or better for this to work. And you have to know the available gear ratios.
Old 09-23-2002, 01:44 PM   #5
Jmac05
L.E.D. Tail lights, Baby!
Jmac05's Avatar
GEARS
I am going to have the rear diff changed in mine within the next few weeks. I believe I have a 4.1 right now, and am sucking gas like an old man's boxers. I have about 100 mile a day commute, and I lose ~ 1/4 of a tank a day. I am debating on whether to go to a 3.07, or maybe around 3.7. anyone have any ideas on the mpg savings between the two? I have gotten used to making punk kids in rice burners look stupid at a stop light, but I don't really tow anything, so the mpg saving would be important.
Prov 3:5-8
"Hook 'em"
L.E.D. Taillights for sale NOW!!!
If interested, visit:
www.earlyclassic.com
or our website:
www.jmcled.com
All 67-72 GM Taillights are on sale untill 5 p.m. on Dec
15th, with Guaranteed Christmas delivery!
joel.mcwaters@jmcled.com
Jmac05 is offline   Reply With Quote
Old 09-23-2002, 01:48 PM   #6
MITCH1914
MITCH1914's Avatar
so if a truck has an open diff only one tire turns at all times?
what you notice that some times both tires turn? in my case when i tap the pedal both of my tires chirp and they both leave a little rubber. but when i step on the peddal only one tire turns hard. i have been under the impression that i have an open differntial what is the deal?
did 68 c-10's come with posi traction? if so i will just rebuild my unit instead of buying a new one
MITCH1914 is offline   Reply With Quote
