Old 01-08-2022, 10:30 AM   #1
RoyL
RoyL's Avatar
QA1 Coilovers Spring Rate 650-750-850?
Coil over Spring Rates Discussed in this YouTube Video, says 750 lb is the most used [starts ~2:45]... What have you guys installed in your C10s?
https://www.youtube.com/watch?v=foX1...JClassicTrucks
My Suburban has no engine, fenders, etc., so can't do any weighing. It's been X-member swapped from a 73-87 C10 and have 2" drop spindles for disc brakes and 1" drop front coils. 4" drop coils in the rear. Had a 350 sbc/TH350 trans, planning on a 5.3/6.0 swap with 4L60/80.
POL Coilovers [Aldan American] state their spring rates are:
Small Block Spring Rate = 450#, Big Block Spring Rate = 550#
https://www.performanceonline.com/19...n-kit-stage-3/
RideTech Coilover springs appear to be P/N - 59080800 Coilspring 8” 800lb
https://www.ridetech.com/instructions/11360201_WEB.pdf
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 01-09-2022, 01:42 AM   #2
SCOTI
SCOTI's Avatar
Re: QA1 Coilovers Spring Rate 650-750-850?
You need to do calculations for the combo to get your target spring rate for starting.
The weight of the front components, suspension pivot point dimensions, & shock angle are some of the things you need to have an idea of to get started. Ridetech has an index w/various component combos to help narrow starting spring-rate choices.
It's definitely not a 'one size fits all' answer so even if you have a similar combo as another guys, the ride quality interpretation is subjective & you may want more/less spring rate vs. what they have.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2022, 02:04 AM   #3
SkinnyG
SkinnyG's Avatar
My '77 daily driver C10 has Moog 6454 1-ton coil springs, which are rated at 1060lbs/in. They are perfectly fine. But ride quality IS subjective.
I would not go softer. I'm also running "Big 10" leafs in the back as well.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-09-2022, 10:22 PM   #4
RoyL
RoyL's Avatar
Thx, understand. I do need to know the basics of my vehicle... still want to know what others have used and their experience with them.
Yes, looks like Ridetech has a nice link to vehicle weights and A and B dimensions on their calculator. https://www.ridetech.com/tech/vehicle-weights/
Suburban is spelled 'Surburban' if you search. Says typical weight with a V8 and 700R4 is 4,500, front weight is 2,280. Used their A-arm data for dimension A and B (10.94" and 16.94"), some trial and error with the angle and spring stroke and spring length.
Guesstimate using the Ridetech coils [73-87 coilover kit includes this spring: 59080800, Coilspring, 8”, 800lb] which results in ~700 lb for a cruiser/daily driver.
If I use QA1's 10" coil, 1OHTXXX, SPRING, 1O" HIGH TRAVEL 2-1/2" ID, results are ~550 lb
I'll have to get QA1's A/B dimensions to be apples to apples, I guess.
1965 Suburban
qa1 coilover
