01-26-2023, 07:10 PM | #1 |
Thermostat Housing Switch
Just curious if anyone still has the complete assembly, and if you do props, does it work. I may never assemble one, but I'm wondering, what do the lines route to? Thanks.
Looks like this, perhaps
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-26-2023 at 09:52 PM. |
01-26-2023, 07:48 PM | #2 |
Re: Thermostat Housing Switch
I believe that's off a newer engine ... probably mid/late 70's or 80's ... not original for 67-72.
Those thermal vacuum switches (TVS) were used to control a variety of things ... like EGR valves and other emissions equipment. |
01-26-2023, 07:57 PM | #3 | |
Sometimes even the vacuum advance on the dist. |
01-26-2023, 09:17 PM | #4 | |
Might be worth mentioning the housing I removed from my 1971 is cast iron, stamped 1595. It's vintage IMO, though I'm not sure it's truck original, and it doesn't have female threads for a switch.
01-26-2023, 11:42 PM | #5 | |
In fact, GM did that from the factory (pipe plug in that hole) on mid/late 70's trucks that were over the GVW threshold to be considered "heavy duty" and didn't require as much emissions equipment as cars & lower GVW trucks. |
01-27-2023, 01:30 AM | #6 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-27-2023, 05:43 PM | #7 |
I can't say with 100% certainty, but I don't think 72 & earlier thermostat housings originally had that female threaded hole in them. I've seen both iron and aluminum versions of the housings without the hole ... I don't know if that was something that changed after a certain year or if it varied by application.
01-27-2023, 06:41 PM | #8 |
The 350/350 in my 72 had the original intake, water neck, and quadrajet, and was an A/C and CA emissions born truck, but no extra provisions in the cast iron water neck.
I only lend the extra info because as we've found out on these trucks before... sometimes it's just a goofy combination of parts ordered that requires different parts like this. |
01-29-2023, 02:18 PM | #9 |
I use one of those to control one of the electric pusher fans. The switch is a 208* switch from a Honda Accord. I had to make the thread adapter. The other fan is controlled by the AC. Both fans are from '90s Cadillacs.
'67 GMC 2500, 292, 4spd, AC |
01-29-2023, 06:22 PM | #10 |
My 81's 250 6 had that. Mostly for smog stuff. I think I still have them. I've seen them use the thermostat housing for a seperate temp sensor for electric fans.
Ibelive the 6 stuff will work on small block also.
01-30-2023, 08:48 AM | #11 |
That is a newer housing. 67-72s didn't have that stuff. A story: I used to stop in the my Chevy dealer on a regular basis to have the parts guy look up parts availability and order what was available. One day I had him check 69-72 truck steering wheels. "It shows they are available but only in black". I couldn't get the words "Order me up one" out of my mouth fast enough. It came in as the current '80s truck steering wheel. That's when I learned GM's concern for supplying parts for their vehicles is offering what will work, not what is correct for a restoration. They print supplemental parts books to list superceded parts numbers for depleted parts numbers
02-05-2023, 08:31 PM | #12 |
Thanks for the education
I forget or never knew. Original housings have a hole for a spring I guess, what for?
02-05-2023, 09:03 PM | #13 |
Who Changed This?
That was for the throttle return spring on a lot of vehicles.
02-06-2023, 07:52 AM | #14 |
I really like those housings with the tab & hole for return spring. I keep those when I find them
02-06-2023, 12:52 PM | #15 |
At the body shop.
Some opened/closed the hot air stove door in the air cleaner.
" That didnt make it any newer " " Dont antique the equipment " |
