Broke
![]() Join Date: Jun 2005
Thread sealant on vac fittings?
What are your thoughts on using thread sealant on vacuum fitting threads? I am plumbing my vac gauge into the rear of my Edelbrock carb. Brass fitting into aluminum carb body. Yes or no on thread sealant?
70 SWB 250 TH400 "The Needy Beast" 200,000 Mile Club Drum Brake Club Daily Driver Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Thread sealant on vac fittings?
I'm no expert but I would definitely use a thin coat of teflon paste on the threads and then wrap teflon tape over the paste. I picked that up from a plumber and it works well on water pipe fittings. Should work equally well on vacuum fittings, especially with dissimilar metals where galling can be an issue.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Jan 2001
On any threads I want to make sure are sealed I use a thin coat of Permatex aviation gasket sealer.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
