Can't see numbers/text on brothers cluster at night
Hello, I recently bought a cluster from brothers. Everything is working good, I swapped all the bulbs out for LEDs. I made sure they are all the right polarity but for some reason the text for the speedo and fuel guage is not lit up very well. I swapped all the pins from a post here from 3 hole to 7 hole pin setup. I don't have the wires ran yet for the ammeter, coolant temp or line ran for the oil pressure. Anyone have any ideas?
Mr. Cheyenne
![]() Join Date: Jun 2020
Re: Can't see numbers/text on brothers cluster at night
Take a look at this Thread, there are ~4 pages (Reproduction Tach Dash Bezel Lens Text Not Lighting Up). In the end there were two issues with these things - likely these dash parts come from the same place. You could have two issues, one with the lens and the other with the tin.
I had both of these problems. GMCPauls resent me a lens but I had to buy a (OEM) Tin from a board member. Now I can see everything light up, even when it is daylight time. Edit Photo added: Though I still need to take it out again to fix the bleed through on the left blinker (damnit LOL).
Richard '72 Chevy C10 Cheyenne Bronze on White [Hook 'em Horns] ![]() SBC 350 | TH350 | LWB | Buddy Seats Last edited by Rich72C10; 04-06-2021 at 11:23 PM. |
#3 | |
Mr. Cheyenne
Sucks doesn't even start to cover this problem that I had - I am so very thankful for that thread, as I am sure I would have never figured it out on my own! GMCPauls did say they reported the tin problem to the source but that means the source would have to re-tool. Which could take a long time, if it ever happens.
At least for the lens, that was just a problem where the source did it wrong. I had to buy a replacement and then got refunded back from GMCPauls once confirmed my lens was painted incorrectly (so they could then send it to the source for their refund).
Richard '72 Chevy C10 Cheyenne Bronze on White [Hook 'em Horns] ![]() SBC 350 | TH350 | LWB | Buddy Seats |
![]() Join Date: Jun 2015
just a question could you use the old tin to mark where the holes should be then maybe drill out the new one then deal with the lens
Mr. Cheyenne
i don't think it was holes ...
![]() Join Date: Feb 2002
If you wind up sourcing an OEM lens out of a junkyard or parts truck, be Very Careful cleaning the backside with the lettering [+numbers]. I wiped out the white stuff with a simple warm damp rag, trying to clean a JY lens. I don't think I even had green soap on it.
A dry camel's hair brush and gently-applied canned air may have worked, but hindsight is 20/20.
![]() Join Date: Jan 2003
I don't have any pictures, but I sprayed the tin gloss white instead of the seafoam green and it was bright with leds.
1969 ![]() 1950 Chevy Wagon 1978 Big 10 |
So.... if I just keep my original lens/tin which are in great shape, and just swap to the LED's, will I run into similar issues?
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
![]() Join Date: Jan 2005
If you use LEDs with your OEM lens and tin, then the text and gauges will be extra bright. The issue the OP is having is likely not caused by LEDs. It is likely the result of a defective reproduction lens and poorly made reproduction tin.
![]() Join Date: Dec 1999
First post said it was working good. When you say you swapped bulbs for led. Did you try it with the standard bulbs? If not I suspect the lens is one of the ones painted on wrong side.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
