Old 10-25-2020, 07:57 PM   #1
72bigred
Look at what I found.. Need to replace..
Doing a 402/700r swap into this 72 blazer.. While everything is out and getting cleaned I figured I would drop the TC and give it a seal kit and clean it up..
It appears someone had a problem years ago.. It has been driven like this for a very long time but I just cannot see letting it stay, any opinions on that? I figured I would just replace it, should I go with advanced adapters or should I try and find a oem adapter?
Thoughts?
72bigred is offline   Reply With Quote
Old 10-25-2020, 08:46 PM   #2
truckster
truckster's Avatar
Re: Look at what I found.. Need to replace..
It's not the prettiest, but it looks like a solid weld, and as you said, it's been driven like that for years.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-25-2020, 09:11 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Moved thread with hopeful intent you’ll get more responses here.
DeadheadNM is online now   Reply With Quote
Old 10-25-2020, 10:01 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
If it was me I’d get a new one personally. The 50 year old oe piece is a crapshoot at best. They are notorious for cracking out. I’ve always heard removing the side mount front e transfer case helps to remedy the problem. My K20 has the side mount removed with no issues.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 10-25-2020, 10:18 PM   #5
72bigred
So your just running with the adapter mount and it floating otherwise?
Old 10-26-2020, 08:13 AM   #6
57taskforce
All about them K’s
That is correct, transfer case bolted to the crossmember only.
Tyler
Old 10-26-2020, 12:08 PM   #7
jeffahart
jeffahart's Avatar
Looks like it's brazed. Probably got the leak sealed though. Anyhow, new aluminum from Advanced adapters are probably only a couple hundred bucks, and they claim much stronger than original. Only thing to ask is the thread size for the shoulder bolt for the transfer shift lever. You may have to get a new pivot/shoulder bolt as well. Use the correct specified gasket and not RTV to seal when assembling(just in case you didn't already know).
j
White K20
jeffahart is offline   Reply With Quote
