Old 01-21-2012, 03:51 AM   #1
70LonghornCST
Moderator
70LonghornCST's Avatar
Adding an AM/FM Decal
I recently acquired an early model van AM/FM radio. It has the Delco inscribed on the lens, which made me think it was an original truck radio. I later found out that it wasn't. The letting on the dial drum was white and a different font. I purchased some reproduction truck AM/FM drum decals to install. However, I could not find any write-up for installing any. So, being the do-it-your-selfer, I decided to do my own write-up.
So, here it goes...
1. Remove the 5 sheet metal screws on the top of the radio.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
70LonghornCST is offline   Reply With Quote
Old 01-21-2012, 03:52 AM   #2
70LonghornCST
Moderator
Re: Adding an AM/FM Decal
2. Remove the top cover. Be careful not too pull to hard so you don't damage the radio light connection at the circuit board.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 03:56 AM   #3
70LonghornCST
Moderator
3. Remove the light bulb from the light housing. Then unclip the light housing from the top radio plate. This will allow you access into the radio to unscrew the two sheet metal screws that fasten the dial drum housing (see step #5).
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:02 AM   #4
70LonghornCST
Moderator
4. Next, remove the front face plate. Remove the flat nuts on the radio shafts. Then, remove the four sheet metal screws holding down the face plate, remove the plate.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:12 AM   #5
70LonghornCST
Moderator
5. Looking down into the radio as it lays flat right side up, you will see two sheet metal screws-one on the left side, and one on the right side of the radio dial drum housing. Carefully remove each of these screws. You will need to move the radio station from one left, then to the right in orider to allow enough room to access the screws. Be careful not to let the screws fall into the radio. The sheet metal screw on the left has a skinny, flat piece of metal that rests on the dial indicator. Study its resting position before removing so you are confident when it comes time to reinstall the screws.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:17 AM   #6
70LonghornCST
Moderator
6. From the front face of the radio, carefully remove the dial drum housing. BE CAREFUL as to NOT stress the dial adjustment string...remember, it's 40+ years old and likely to be on the brittle side. Also be careful not to scratch the orange paint on the back side of the indicator needle as you remove the dial drum housing.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:26 AM   #7
70LonghornCST
Moderator
7. Clean the AM/FM drum with water and a Q-Tip. I did this step out of order. It will actually be easier to clean once you remove the dial drum from its housing.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:33 AM   #8
Tuff Gong
Tuff Gong's Avatar
this is a nice thread. What is the small metal piece on the left side for? Sorry, just realized I should have waited until your steps where done to comment.
Tuff Gong is offline   Reply With Quote
Old 01-21-2012, 04:34 AM   #9
70LonghornCST
Moderator
8. Remove the dial drum from its housing: In order to do this without causing any damage, you will have to spin the dial inside of the housing until the little plastic tab on the right end of the plast drum lines up with the hole on the right side of the houseing (shown in this picture). Shift the drum so the little pin slips into the hole. This will allow you carefully lift the left side of the drum up and out of the housing. Be careful to study the position of the tension spring on the right side. Note the direction that it sits on the its pin.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:39 AM   #10
70LonghornCST
Moderator
9. Next, you will need to prepare your decal. They are printed with a bit of extra black area that you will need to cut off to fit properly. Take some measurements off of your original dial and mark your decal for cutting. Once the decal is cut, remove the backing paper and carefull apply it to the drum. Be careful when applying it so you do not get any air bubbles.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 04:52 AM   #11
70LonghornCST
Moderator
10. Once the decal is firmly in place, reverse the order of removal. Take your time. Be sure to remember when reinstalling the face plate that you line up the AM/FM switch lever with the indicator shaft so it will flip to AM/FM when you move the lever.
Once it's all back together, enjoy your new truck AM/FM radio
I hope this write-up helps.
-Richard
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 05:14 AM   #12
70LonghornCST
Moderator
No problem, Brian. I am not sure what that piece of metal is for. It's either for tesion on the AM/FM switch so it is not sloppy, or to keep it from traveling too far in a given direction. I'm just guessing, though.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 01-21-2012, 06:35 AM   #13
rsavage
rsavage's Avatar
Thanks for the great how-to and pictorial. Hope the moderators make it a sticky.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-23-2012, 03:06 AM   #14
sleepertruck72
sleepertruck72's Avatar
Nice Job Richard
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-23-2012, 12:11 PM   #15
bollybib
bollybib's Avatar
Nice job x 2.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 01-23-2012, 01:23 PM   #16
sameyrasmea72
sameyrasmea72's Avatar
Cool write up !!! Hope this helps with my radio. One day I looked down and the dial was just missing. I hope it is an easy fix. I bet it would be difficult to find parts.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-23-2012, 03:36 PM   #17
RenoKeene
Florida Edition
RenoKeene's Avatar
Thanks for sharing, you are very talented...I read your build thread too.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-23-2012, 04:58 PM   #18
70shortfleet
70shortfleet's Avatar
I think your string broke and the drum rolled around to the backside
70shortfleet is offline   Reply With Quote
Old 01-23-2012, 06:39 PM   #19
sameyrasmea72
Is that an easy fix??? The radio worked fine but now I get nothing.
72 Cheyenne Super
Old 01-23-2012, 06:49 PM   #20
VA72C10
VA72C10
VA72C10's Avatar
Nice writeup! Recommended for FAQ!
Old 01-29-2012, 02:50 AM   #21
70LonghornCST
Moderator
My pleasure! I wanted a thread like this but could not find one...so I decided I'd make one for myself and others.
Originally Posted by sleepertruck72 View Post
Nice Job Richard
Thank you Jorge!
Originally Posted by bollybib View Post
Nice job x 2.
Thanks!
Thanks, Jason. I talked to your dad a few nights ago about firewall grease pencil markings. I also think your string broke. The removal procedure that I have posted will give you access to where you need to go. You will need to get a very tough nylon type string to re-tie your dial. It will be a little bid tedious tying a small string, but very doable. I had to do that once.
Thanks for the compliments
Thank you, Jonathan!
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 02-18-2012, 08:31 PM   #22
augie
Waiting for Paul to Open Safe
augie's Avatar
Awesome write up Richard a copy can now be found in the FAQ area http://67-72chevytrucks.com/vboard/s...d.php?t=509765 Thanks!
Norwood Survivor
http://squarebody.net
augie is offline   Reply With Quote
Old 02-19-2012, 12:04 AM   #23
70LonghornCST
Moderator
Awsome! Thank you, Augie! I hope it serves as a useful thread for some of your board members.
-Richard
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
