Old 01-14-2022, 01:26 PM   #1
kwmech
Dimple Dies
Been trying to find a couple of smaller sizes and am coming up short.
Sizes: 1/4''--5/16'' and 3/8''
anybody?
Can find larger sizes up to 3'' and smaller down to 3/32'' for aircraft. For some reason those 3 sizes come up blank
Old 01-14-2022, 01:30 PM   #2
geezer#99
geezer#99's Avatar
Re: Dimple Dies
Have you tried the metric equivalents?
Old 01-14-2022, 02:33 PM   #3
kwmech
Re: Dimple Dies
Nope, not a bad idea----nothing found but the same searches that came up prior
Old 01-14-2022, 04:07 PM   #4
typerr
Re: Dimple Dies
anybody?
Try Trick-tools.com they seem to have a wide variety.
typerr is offline   Reply With Quote
Old 01-14-2022, 06:12 PM   #5
SCOTI
SCOTI's Avatar
Re: Dimple Dies
Trick Tools or Hammerfab
https://www.hammerfab.com/shop/p/crater-maker-set
https://www.trick-tools.com/
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2022, 06:42 PM   #6
kwmech
Re: Dimple Dies
Nope, both Hammer fab and trick tools start at 1/2'' and go up from there. Thanks for the links.
What I'm trying to make is a non-slip tread plate out of 18 ga for some custom running boards I'm making for my 91 Suburban, hence the smaller dimples
Old 01-14-2022, 07:14 PM   #7
SCOTI
SCOTI's Avatar
Re: Dimple Dies
Well.... My bad. I could of sworn Levi had some to 1/4" in size.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-14-2022, 09:19 PM   #8
kwmech
Re: Dimple Dies
Not according to his website anyways
Old 01-14-2022, 10:13 PM   #9
BigBird05
Re: Dimple Dies
I just read an article that a guy used some sockets for dimple dies because he didn't have any. I thought it was on here. But I can't remember.
BigBird05 is offline   Reply With Quote
Old 01-16-2022, 11:32 AM   #10
Accelo
Accelo's Avatar
Re: Dimple Dies
If you have a drawing of exactly what you want I may be able to make a set for you? PM me if interested.
Accelo is offline   Reply With Quote
Old 01-16-2022, 01:17 PM   #11
SCOTI
SCOTI's Avatar
Re: Dimple Dies
Whether it happens or not..... Awesome offer!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-16-2022, 03:46 PM   #12
roboticjunky
Re: Dimple Dies
This set comes with #8, #10, 1/4, 5/16, and 3/8.
https://www.hammerfab.com/shop/p/raised-recess
roboticjunky is offline   Reply With Quote
Old 01-16-2022, 04:34 PM   #13
kwmech
Re: Dimple Dies
Actually I'm not exactly sure what I want. I do want to create a non-slip tread on 18g steel for some frame mounted running boards/rock sliders for my suburban. I thought a smaller dimple would work if I can get a set of dies that I could utilize in an arbor press or on my small bench top hydraulic. Saw some where in my searches that maybe a 3/16 may work.
Old 01-16-2022, 09:07 PM   #14
Spud2276
Re: Dimple Dies
Brown Avaition Tool, Oklahoma City has dimple dies the size you are searching for. They are online
Spud2276 is offline   Reply With Quote
Old 01-17-2022, 12:21 AM   #15
Accelo
Accelo's Avatar
Re: Dimple Dies
The 5 Piece Raised Recess Dimple Die Set by hammerfab is
$360.00
The other set is $55. Used a rivet tool.
I did a Google search and didn't find them. Good sleuthing guys.
cheers.
Old 01-17-2022, 05:55 PM   #16
roboticjunky
Re: Dimple Dies
These would be good for step or tread plate, but it's $195.
https://www.hammerfab.com/shop/p/flush-recess-die-set
Old 01-17-2022, 11:16 PM   #17
JJH Jimmy
JJH Jimmy's Avatar
Re: Dimple Dies
Not sure what your design is but you can buy dimple tread material.
https://www.directmetals.com/product...afety-grating/
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 01-18-2022, 10:22 AM   #18
kwmech
Re: Dimple Dies
Well that makes it too easy---thanks
