08-30-2021, 09:45 AM | #1 |
Post Whore
How many miles have you driven your truck?
How many miles have you driven your truck? And over how many years? Is it carbed or injected? Do you have an overdrive?
I've put 33k miles in 4 years on the Burban. Running a generic 350 with a Qjet and it got a Gearvendor last year. These questions came about after some beers with friends, one of which quite sure I'm the only person who still daily drives a carbureted truck. Maybe I am but I doubt it. What do you say?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 08-30-2021 at 09:00 PM. |
08-30-2021, 10:05 AM | #2 |
Who Changed This?
Re: How many miles have you driven your truck?
I've had my truck about 9 years, bone stock. I've probably driven it 5k miles. The carb usually dries up between uses, but I have an electric fuel pump that I use to fill the carb back up before cranking it up. It has 217k miles on it (rebuilt ~100k ago). If I drive it every day, it fires right up.
08-30-2021, 10:52 AM | #3 |
I finished my C10 this last spring. It has a 4 barrel carb, TH400 (no overdrive), and 3.08 single-spin-rear-end. I have put 1600 miles on it in about 4-5 months.
Like all the carbed engines I've owned...give it a few days and it takes a bit to get it started due to the dry bowls. Steve, enlighten us on how your electric fuel pump is plumbed and wired. Is in lieu of the mechanical pump? I have 3 vehicles that I rotate through the year. A wintertime '85 K20, a spring & fall '72 C10 (no AC), and a heat-of-the-summer, '67 Rustang (with AC). It all depends on what the weather is like, so they all get started most weeks, but all go dry regularly. All three are carbureted...the K20 (with overdrive) used to get a few thousand miles a year. I drive about 5-6 thousand miles a year total and will try to balance that between the three, but the K20 will see most of it due to the longer winter season. The 67 has a manual overdrive and has seen 14,000 miles since it's completion in 2013.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
08-30-2021, 11:01 AM | #4 |
Location: Herculaneum MO (20 minutes south of St. Louis
I've had my 67 C10 about 2 years & have put about 25k on it in that time. It is my daily driver & still run the original 2 barrel. I have to laugh at people who think they need fuel injection to be reliable. Nothing starts up faster than my 283, I can drive away immediately have have the choke off within 2 blocks of my house unless it is really cold out.
My 67 C20 I've had about 2 and 1/2 years & I've put about 7k on it. It's a little more cold natured but that's to be expected from the inline 6. I still wouldn't go fuel injection, heck this truck gets 15mpg with the 4 spd & 4.56 rear gears.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-30-2021, 11:08 AM | #5 |
Squarebody - but it was a daily driver for 30 years and 200,000 miles.
Fuel injected, manual overdrive, 3.73 gears. More related to classic vehicle usage: I drive my '63 Grand Prix about 1000 miles per year (carb, no overdrive, 3.90 gears). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-30-2021, 12:23 PM | #6 |
Have owned this GMC for about 6 years. I drive it every day to work and here lately, have been hauling logs for firewood. Never misses a beat. GM crate 350, TH350 and a 373 rear. Some guys say i can haul as much as a 3/4 ton and has leaf springs. I wouldnt trade it for anything….ok maybe a 4x4 ��
Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors Last edited by tommy3horse; 08-30-2021 at 12:25 PM. Reason: Pic |
08-30-2021, 12:24 PM | #7 |
Less than 1 mile.
08-30-2021, 01:24 PM | #8 | |
Who Changed This?
08-30-2021, 01:39 PM | #9 |
I finished a frame off restoration on my Cheyenne Super in 1990. I have driven it to Des Moines, Gatlinburg, Bowling Green, Biloxi, Nashville, Pensacola etc..
It is completely stock except for the drop. carbureted 350, 350 turbo with 3.08 gears. I have put just over 36,000 miles in that 31 years, but I have had other 71 and 72's all that time, and drive a 71 or 72 most everyday. I estimate I have put 180,000 to 200,000 miles total on all of them in the last 30 years, and all had carburetors.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
08-30-2021, 02:02 PM | #10 |
I've had this truck since '93. I have put many tens of thousands on it, but the Speedo/Odo combo doesn't work, so i can't tell you how many.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
08-30-2021, 03:11 PM | #11 | |
Woody |
08-30-2021, 03:49 PM | #12 |
Since I received my C/10 (Zooey) as a graduation gift in high school back in 2008 I have driven Zooey as least a quarter mile that is the length of my driveway. I got halfway down the driveway and realized that my brother-in-law who took it for a test drive forgot to lock the seat and, the manual brakes were out. So I stepped on the brake pedal the seat lurched forward I thought I was going to die . I was able to get it to come to a complete stop before I said nope, screw it I'm not driving this truck anymore until I've got it completely rebuilt from the ground up. And as usual life gets in the way the Bodywork is 95% done I've still got everything else left to do.
08-30-2021, 06:15 PM | #13 |
Mine was my wife’s grandfathers daily. Had 76k on the clock from when he owned it but he worked her hard. I drove it about 250 miles then did a frame off resto-mod restoration on her about 11 years ago. Since then she has only logged 546 miles. She maybe going back under the knife again this winter as I have a friend who’s 2009 hybrid Tahoe just had a tree dropped on it and wants me to have the driveline. I keep contemplating a 71 GMC hybrid might be an interesting project if not just pull one out of a field and do it.
08-30-2021, 06:54 PM | #14 |
70+ ( Old Skool Club )
Bought my 72 C10 in 2014 with 85,000 miles on and now 7 years later has 92,000 so I guess about 1000 miles a summer season. Original 350 with QJet 4bbl and TH350 till 2019 when 700R4 went it. I park inside for the Winter then 3/4 pumps on the gas in the Spring and away she goes.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " 4 Things When Used are Gone Forever " " A Word After it is Said - A Missed Opportunity - Time once Passed - Trust after its Lost " RIP Charlie Watts 1941 - 2021 |
08-30-2021, 06:54 PM | #15 |
BlahBlahBlah
If only this thread said pushed instead of driven =)
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
08-30-2021, 07:55 PM | #16 |
I have several vehicles . But I have put 31k on my 72 since 2018 350 edelbrock 1406 carb turbo 350 with 4.11 rear . My main rode to truck shows. But I have also put over 8k on the 85 k20 since February of this year.
08-30-2021, 08:46 PM | #17 |
Let me preface this with saying I was career Army and since I bought my truck I spent about 15 years overseas, so my truck spent that time in storage or with my son.
I bought my truck 29 years ago with 139,xxx miles on it. The engine was “Overhauled” at 129,xxx miles (I found out later it was a VERY shoddy job). 1998, At 159,000 I did a complete rebuild of the Engine and Transmission. Since then I’ve put 15,000 miles on her, but actually use her very little, and when I do she doesn’t miss a beat. She hasn’t seen salt since I bought her and rarely gets taken out on the road in the rain. I love my truck, and my wife knows that she will never be sold. |
08-30-2021, 08:52 PM | #18 |
I was going to say. 01 miles, down the driveway and onto a trailer.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
08-30-2021, 09:09 PM | #19 |
1972 SWB, factory PS, PB, AC, Carbed 350/350THM 3.73. Total about 80K over almost 25 years. About 25K since frame off.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-30-2021, 09:37 PM | #20 |
I have a 68' C-20 that I bought in 2002. I have driven it off and on and it sat for 3 years a while back. The trans went out but after a fresh engine and trans I have driven it every day for the last two years and put 35,000 on it. I would drive it any where. 350 crate with a TH 350 trans and Edelbrock carb.
68' with no bells or whistles unless I add'em. |
08-30-2021, 09:52 PM | #21 |
I've put over 30,000 miles on this one in the last five years.
08-30-2021, 11:41 PM | #22 |
recently drove my 68 240 miles round trip, AC on, no problems
08-31-2021, 01:53 AM | #23 |
When I bought my '68 C/10 Stepside in 1973 it had about 80,000 on the Odometer. Now it's indicating 401,000+. So about 321,000. Actually it feels like it drives iself.
Set up is: L6 292/SM465/3.73 Eaton Posi. No O/D. 4V Edelbrock 1404 carb [500 CFM], Offy intake, Clifford headers, HEI.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-31-2021 at 02:04 AM. |
08-31-2021, 02:31 AM | #24 |
My speedometer/ odometer hasn't worked in nearly the entire time since I've owned it. In November of 2020 I put in a new after market unit and have logged in 5,365.1 miles of daily driving it.
1968 C10 327 4 barrel Q-jet with manual 3 speed tranny and 3:73 to 1 rear end. |
08-31-2021, 02:33 AM | #25 | |
Thread Tools | |
Display Modes | |
