01-12-2021, 09:18 AM | #1 |
attaching lower grill bar to grill ... how ?
Truck is '56 shortbed. Trying to mount the upper and lower grill bars to my front grill. Upper is fine, but for the lower I could use some advice.
I was able to fix the upper bar with the 4 screws that go into the grill, and the 2 bolts that go in the bracket : On the bottom side of the grill, I see the screws (red) and the brackets (green) : But the lower filler panel only has 4 tabs (red) that somehow correspond to the screws in the grill... there is no hole (green) where the bracket is. I say 'somehow correspond', cause when I measure, the lip of the grill (yellow in the upper picture), is pushing against the yellow line, and scratches the paint ... I would think that this lip would land between the lip and the flat area.
'56 Chevy stepside shortbed SBC350 - TH350 12-bolt rear |
01-12-2021, 03:04 PM | #2 |
Re: attaching lower grill bar to grill ... how ?
It's interesting as when you look at the assembly manual, it shows 6 bolts across the bottom of the grille to attach it to the filler panel. 4 using the brackets and the 2 outer using holes where you marked with green. If you look at aftermarket panels, only ones for a '57 have these outer holes (but no brackets as there are additional holes punched into the panel). I do have an original '55/56 grille and it does have the outer brackets like your grille has. Maybe someone more familiar can chime in.
01-27-2021, 09:52 PM | #3 |
Hey could it be you have the lower apron is from a 57. The grills are different maybe they have different or more mounting holes. Thank you Happy truckin
01-28-2021, 06:12 AM | #4 |
figured it out in the meantime ... only had to use the 4 bottom and 4 top screws from the grill... I got confused by the brackets...
01-28-2021, 02:48 PM | #5 |
just a hint to save paint, they sell little plastic washers at the hardware store to go under the screws, then the screw heads don't dig into the paint.
57 had a different grill idea and parts of it went around the grill surround hole and sort of covered it up. the grille surround has a divet in it where the bracket screwed on. |
01-28-2021, 02:50 PM | #6 |
01-28-2021, 02:51 PM | #7 |
in case somebody else is wondering, the 56 looks like this and the grill fits inside the opening.
http://coloradoguy.com/1957-chevrolet-truck/photos.htm |
