05-31-2023, 01:32 AM | #1 |
HEI power wiring...
I have a 74' with HEI ignition. The factory HEI wiring is completely gone. I have it powered incorrectly and its melting the insulation on a tan wire Im using from the firewall bulkhead.
I would like to properly wire the Positive + power supply to the coil. Looking at the schematic (my interpretation) the + is a 20G Y (Yellow) labeled 20Y 7A which splices to 20Y 7B. The 20Y 7B looks like it attaches to the R terminal on the starter solenoid. Is this correct? From 20Y 7A it also splices off to 20 P/B 3. What is P/B? is it pink or blue or purple or blue? This wire then appears to terminate at the firewall bulkhead engine harness terminal 3. The schematic also calls for a 1.35 Ohm resistor for the V8 engine where is splices at 20P/B 3. Do I need the resistor? Basically do I just need to run a wire from the + Terminal on the coil to the R Terminal on the Starter Solenoid, add in a splice wire back to the number 3 terminal on the firewall bulkhead engine harness?
Welcome to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574370 |
05-31-2023, 02:42 AM | #2 | |
Re: HEI power wiring...
This one is easier to read.
05-31-2023, 07:53 AM | #3 |
Pretty interesting, my 74 still had points ignition.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
05-31-2023, 08:12 AM | #4 |
As did mine Al.
All the wiring is gone for the hei because it never existed. All you need is a dedicated 12v power source for the hei. Either from a 12v spade on the fuse box or from the ignition switch. The yellow wire and resistance wire are not needed for an hei. |
05-31-2023, 12:25 PM | #5 |
1974 would be a points ignition system. If you are converting to HEI then you need to replace or route around the resistor wire and up grade to 12 ga wire. I usually will run a bypass wire from the bulkhead connector and where it plugs the original resistor wire in the bulkhead connector. The yellow wire that runs down to the starter is the R wire that supplies power to the coil in cranking. Early ignition switches did not allow power to the ignition system when cranking the engine.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
05-31-2023, 01:34 PM | #6 |
My '74 was also points but I converted to HEI. I removed the factory distributor power wire from a ~76 parts harness I had and replaced the resistor wire my '74 had. Easy swap and looks factory since I used factory wiring.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-01-2023, 07:24 AM | #7 | |
06-02-2023, 06:26 PM | #8 |
HEI Power & By-Pass Wiring...
" Early ignition switches did not allow power to the ignition system when cranking the engine. "
Not sure where you ever got that idea . The entire point of the second terminal on the starter solenoid was to by pass the calibrated ignition wire from the key switch when cranking so the spark was stronger . I add HEI systems to everything and my simple method is one of those tiny cube relays that's rated for 50 amperes, kicked by the low power feed (7 ~ 9 VDC) from the key switch . Easy and doesn't hack up the factory harness and isn't glaringly obvious .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
06-02-2023, 07:54 PM | #9 | |
Re: HEI Power & By-Pass Wiring...
The OEM coil will draw 50 amps? I like the idea of running it this way. I need to add a fusible link and I plan on connecting it to the accessory lug on the factory busbar. Do you run a fuse? How big of a fuse is needed?
06-02-2023, 09:29 PM | #10 |
Ignition Power Requirements
No ;
Either way draws under 15 amperes . Ignition systems are typically not fused for safety reasons, I don't -ever- fuse them as I don't think I know more than the Engineers . If it worries you, set up a separate dedicated power circuit and add a circuit breaker .
