11-13-2020, 03:45 PM | #1 |
Speedway motors Ford 9 inch?
Was running the numbers for rebuilding my 12 bolt and came across the Speedway Motors Ford 9inch they make in house, specifically for the 67-72 trucks with the trailing arm perches already welded on. It’s only $500 and if I wanted to use their third member (the manufacture of the posi and gears is not listed so I assume they are off brand) I could have it all put together for less than $2K.
Anyone have any experience with one? Not interested in a Ford debate- just looking for new options as I figure I will be in my current rearend rebuilt (accounting for the tools I would buy to set it up myself or have someone do it for me) for as much as there whole rearend is. Nick |
11-13-2020, 08:05 PM | #2 |
Re: Speedway motors Ford 9 inch?
I have seen a few friends use them, and the housing is as good as anything the factory put out from what I have seen. Just with the best factory stuff.
So unless your shooting for the stars HP wise it will be more then good enough. |
11-15-2020, 12:54 PM | #3 | |
I am going through rear end selection right now, and haven’t seen the speedway unit that is specific to our trucks (with the trailing arm perches). Can you link to what you’re seeing? Thanks’ Chris |
11-15-2020, 06:19 PM | #4 |
Another option might be Quick Performance out of Iowa. They build a ton of different 9' combos.
Nothing against Speedway. I've bought a ton of stuff from them over the years. One thing to check is the u-joint size. Many use the small 1310 size. If you are building from scratch you might as well upgrade to the 1350 u-joints. Also check housing ends to see if they are compatible with your stock stuff. |
11-15-2020, 07:08 PM | #5 | |
Moderator
https://www.speedwaymotors.com/Bolt-...cks,80935.html The image shows a leaf spring housing, however, the text mentions railing arms...I would be triple checking the mounting design before spending any dollars...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-15-2020, 07:47 PM | #6 |
Moderator
Wow, you can't hardly beat that price.
11-15-2020, 09:16 PM | #7 |
Moderator
Remember, the price listed is for the bare housing only....
Axles, center, seals etc are all extra...
11-18-2020, 07:25 AM | #8 |
Upon doing a little more research, I’d probably just use the housing and put a different, name brand third member in it as it seems Speedway Motors stuff is more directed to mild engines. Even though my engine won’t be there yet, I’m trying to get all the drivetrain to be built to handle 550-600hp so I just have to do it once.
Still trying to figure out if I want to spend $400+ on tools and beef up the 12 bolt or just buy a 9” I can put together for a fairly comparable amount. Decisions, decisions. |
11-18-2020, 10:54 AM | #9 | |
11-19-2020, 10:06 PM | #10 |
I have this housing collecting dust and no I’m not trying to sell it. Here’s some pics of quality. I’ll let you judge for yourself. Want more pics, let me know
Customization is what you want it to look like -- not what other people think it should look like |
11-19-2020, 10:09 PM | #11 |
More pics
11-22-2020, 09:33 PM | #12 |
I would highly recommend Quick Performance. Ive never looked to see if they have a truck housing kit but they have one for just about every other car and their prices are tough to beat. Plus they can do custom widths for you too. I bought one of their kits for a old chevelle project and the housing fab work was top quality.
Anthony |
11-25-2020, 04:38 AM | #13 |
Thanks for the pictures. You can definetly tell they use a reclaimed housing (looks a bit rough)- welds on tubes and perches look great, but not that good on the panhard rod attachment they added. What are your thoughts on the quality having seen it in person?
Did a bit more math and it looks like I can rebuild the 12 bolt as stout as I really can (Detroit Trutrac, Moser axles, richomond gears, rebuild kit, Moser rearend cover, 1350 pinion yoke) for about $1,400 not including the tools which will be another couple hundred. Leaning a little bit that way now. |
11-25-2020, 05:16 PM | #14 |
If you decide to go with the 12 bolt I would weld the axle tubes to the center section. Also if you buy Moser axles you might think buying them with a 4.75" bolt circle. Lot more wheel choices with 4.75" bolt circle. You can convert the front hubs also.
11-26-2020, 05:39 PM | #15 | |
Anthony |
