Old 02-09-2023, 08:02 AM   #1
Johnl48
What's this part ?
There is one of these on each side of my Frame but I don't see a function for it. Any ideas ?
Old 02-09-2023, 08:19 AM   #2
Bigdav160
Bigdav160's Avatar
Re: What's this part ?
In case the spring breaks, and they do break occasionally, that you don't lose your steering also.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-09-2023, 08:57 AM   #3
I've never seen this on both sides, only driver side. The drive side front mount should also have a strap welded across the front
Old 02-09-2023, 12:04 PM   #4
6t727t2
Active Member
Listing this one now in FS if anyone needs one
6t727t2 is offline   Reply With Quote
Old 02-09-2023, 12:20 PM   #5
A1971Blazer
A1971Blazer's Avatar
If you have factory front springs, it's OK to leave this in place.
If you have lift springs it needs to be removed or it will severely limit rearward movement of the spring.
The factory springs have a negative to relatively flat arch to them, when the spring compresses the shackle moves forward,
a lift spring has positive arch so when it compresses, the shackle moves rearward.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-09-2023, 01:16 PM   #6
Johnl48
Interesting ! I have a 4" lift
Old 02-10-2023, 06:25 AM   #7
ohboy321
ohboy321's Avatar
My K10 had one on each side with stock springs, and when I installed 2" lift springs I had to remove both because they were hitting.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke
2007 BMW X3
2020 BMW 540xi
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
