10-11-2021, 02:27 PM | #1 |
Help Decoding VIN
Hi... Wondering if anyone can help me decode the VIN on this truck. It is OC412N123870. I believe it is a 1960 but that's all I know. Trying to help a friend out. Thanks!
10-11-2021, 03:52 PM | #2 |
Re: Help Decoding VIN
Hope you can make sense of this...
1960-64 Chevrolet Serial Identification Number The serial identification number is located on a plate attached to the door frame. 1 C 15 4 F 103455 Model Year 0 = 1960 2 = 1962 4 = 1964 1 = 1961 3 = 1963 Chassis Designation C = 2WD K = 4WD Series 14 = 1/2 ton Shortbed 115" Wheelbase 15 = 1/2 ton Longbed 127" Wheelbase 25 = 3/4 ton Longbed 127" Wheelbase Truck Type 4 = Pickup Assembly Plant A = Atlanta J = Janesville P = Pontiac Z = Fremont B = Baltimore K = Kansas City S = St. Louis 1 = Oshawa F = Flint N = Norwood T = Tarrytown Vehicle Number 3,455th unit built Each year begins with serial number 100,001 |
10-11-2021, 03:57 PM | #3 |
Moderator
1960 Built in Norwood. But the C412 (in 1960) has me gerfunkled.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-11-2021 at 09:16 PM. |
10-11-2021, 04:32 PM | #4 |
"The Rocknrod"... OK, so at least I'm not the only one that's stumped. I think the C is for two wheel drive (C Series) but the 412 I can't figure out. Thanks
10-11-2021, 04:35 PM | #5 |
Here is a picture of the VIN
10-11-2021, 05:16 PM | #6 |
Thanks gmc Jr van...
10-11-2021, 08:36 PM | #7 |
Norwood Ohio assembly plant, near Cincinnati.
10-11-2021, 11:13 PM | #8 |
Have your buddy/or you check out this site at GM Heritage:
https://www.gmheritagecenter.com/doc...olet-Truck.pdf On page 7 it shows Designation “OC412…” as Series C4102 then you can look at page 11 & 25 for load capacity, weight distribution, etc. Should help get some facts about it. Thanks for the photo it looks like an interesting build!
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
