05-01-2021, 11:40 PM | #1 |
Which Oil Filter
I did a search and I did not find any recent post on Oil Filters...
I have a 402BB ... what are some of the better Oil Filter brands? Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-01-2021, 11:47 PM | #2 |
Re: Which Oil Filter
I’ve found you can’t go wrong with Wix or Baldwin.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
05-02-2021, 07:31 AM | #3 |
I swear by Napa Gold,which is Wix,DO NOT use Fram!!!
05-02-2021, 08:30 AM | #4 |
x1,000
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-02-2021, 08:55 AM | #5 |
05-02-2021, 09:41 AM | #6 |
lots of videos on u-tube on the subject , don,t know if fram was there
05-02-2021, 04:35 PM | #7 |
I usually use Wix - they make really good filters. I've used Bosch as well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-02-2021, 04:54 PM | #8 |
Cut one open and have a look for yourself.
Fram filters are absolute junk. As stated before, Wix is great, Napa gold (is Wix) so also a great filter. K&N are great filters, Heck, Micro guard and Pro-Tec ain't bad. My buddy used to have a canister filter on a '49 FORD that he filled with tampons ...That might have been worse than Fram ...But I'm not sure Here are some more oil filter comparison videos. FWIW, I run WIX on all my cars and trucks, K&N on the bikes. -Russ
Insert clever text here: |
05-02-2021, 05:09 PM | #9 |
Facts!
Still don’t see any! I’ve Cut open more filters than you and those YouTube wannabe’s. If fram is so bad then why have they been around for 90 years! |
05-03-2021, 08:33 AM | #10 |
Maybe try those old toilet paper ones,remember those?
05-03-2021, 09:25 AM | #11 |
I had trouble with Wix filters for my 67 AMC 232 engine. The anti-drain back valves (ADV) didn't work and the engine would rattle like crazy on start up. It took me three filters before I figured that out. My preferred filter for that engine is Purolator but the cheap Fram oil filters also worked OK. If a filter with supposed ADV pours oil out the outside holes when you remove the filter then the ADV is not working. I will use Wix on other applications, like I may have one on my 350.
I had a Fram ultra-guard filter collapse in the winter time on my wife's Volvo XC90. It just did not let enough cold oil through it. Since then I have gone back to using the dealer filters. At a car show a fellow was showing me the Fram filter he was going to use and I noticed steel slivers around the outside holes. Maybe just an anomaly but the plate obviously didn't get punched out cleanly. I only ever saw that the one time. Other than these observances I've used a lot of Fram filters over the years with no known bad results. Last edited by vince1; 05-03-2021 at 09:44 AM. |
05-03-2021, 10:18 AM | #12 | ||
Fact: Fram uses the same inferior paper on the ends of the canister rather than metal caps. Fact: You will find rust in the majority of fram filters when you cut them apart. Fact: You have no idea how many filters I've cut apart. Quote:
05-03-2021, 10:41 AM | #13 |
Correct me if I am wrong but the Wix 51061 application for my 350 truck does not show an ADV whereas Fram, Purolator and AC-Delco do. My truck's next filter will have an ADV whether it needs it or not.
I hope this will provide some insight to the OP, although I don't know if his filter application is the same. |
05-03-2021, 11:23 AM | #14 | |
05-03-2021, 11:39 AM | #15 |
ADV=Anti-drain back valve
For those that will read this thread and are not certain what ADV stands for or what it does: Anti-drain back valve prevents oil from draining out of the oil filter when the engine is turned off. You can find a ton of information about this online. As well as Oil filter reviews, ratings, opinions etc. FRAM uses a silicone ADBV on FRAM Tough Guard and FRAM Ultra filters, and switched to a silicone ADBV on Extra Guard filters in 2018 because of its superior performance.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
05-03-2021, 11:46 AM | #16 |
The Wix 51258 including the Napa equivalent did not work for me on the AMC. All the oil ended up back in the pan. For that reason I wouldn't trust the 51060 either.
Anybody using the 51060, when you spin off the filter and lay it on its side, does oil come out of the outside holes? If yes ADV not working, if no then ADV working OK. At least those are my findings. Last edited by vince1; 05-03-2021 at 11:58 AM. |
05-03-2021, 11:22 PM | #17 |
ADV = anti drain back valve is only needed if the filter is mounted on its side or top . our old engines with bottom mount dont drain back much at all . . and if they did we got bigger problems ..
seen and heard to many storys on fram SH!T so i just go wix or purolator for my top 2 .
05-05-2021, 09:46 PM | #18 |
Purolator is my favorite filter, but wix baldwin are good, ive used stp from auto in a pinch on customer cars will not runa fram i did find out fram was bought out by mann-hummel so im goignt og ive it a few months and by one to cut open to see if they changed anything
05-07-2021, 12:42 AM | #19 |
Thanks for all the input
