Old 04-29-2021, 01:44 AM   #1
Greasey Harley
Greasey Harley's Avatar
98 silverado electric fan upgrade
99 Silverado with a clutch fan.
We found a newer suburban parts truck with dual electric fans.
do I just need an aftermarket wiring harness to make this work?
The harnesses I have found say it plugs into the PCM. Will the PCM recognize this on a truck that never had electric fans?
FWIW, I'm a carburetor guy, this is for a buddy's truck. I have no idea how to wire components into a confuser controlled vehicle. I could wire it completely separate from the PCM, but I ain't sure the truck would like that.
Usually in the old truck section
-Russ
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 04-29-2021, 12:34 PM   #2
EVRLET
EVRLET's Avatar
Re: 98 silverado electric fan upgrade
You have two options for wiring.
Install to where it comes on with temp switch, no pcm control.
Or install with pcm control but you’ll need to get into the pcm with HP Tuners or some other software to set up e-fans. Then the computer will control the fan. The PCM has to be an LS based pcm.
If you have the 411 pcm already controlling your L31 engine, then you can use HP Tuners on that.
I just installed e-fans in a 2003 Denali and went into the PCM to set it up. If you found the e-fans on a factory suburban, grab the relay box and all the wiring for it. The relay box is attached to the main under hood fuse box. With this, you don’t need any aftermarket wiring kit. But you will need to have it pcm controlled.
The factory relay box looks like this:
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 04-29-2021, 07:53 PM   #3
Greasey Harley
Excellent, thank you.
Is the harness off the suburban a stand alone harness, or will it have to be separated out of the main harness?
Don't mind spending 50 or 60 bucks on a harness, if it's going to be a cleaner/easier install.
Old 04-29-2021, 10:41 PM   #4
EVRLET
EVRLET's Avatar
Yes it’s a stand alone.
Old 04-30-2021, 12:27 PM   #5
Tom
driving is in my blood
Tom's Avatar
Blackbear can turn Efans on in 1998 model ECU's, you don't need an 0411 computer swap. Doesn't work on 97 and lower although I don't remember what they said was the reason.
Old 04-30-2021, 06:37 PM   #6
EVRLET
EVRLET's Avatar
I’m curious now. What 1998 truck had factory efans that the PCM would have this tab available for turn on? Is this an LS based PCM from a Camaro or Corvette that had an LS1?
Old 05-01-2021, 12:41 AM   #7
Just call me Sean
Just call me Sean's Avatar
Black plug pin 9 dark blue wire is labeled auxiliary electric cooling fan for 98-99. I rewired my 99 to take a 96 computer.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-01-2021, 12:11 PM   #8
EVRLET
EVRLET's Avatar
Groovy. Learn something new
