01-05-2021, 02:47 PM | #76 |
Re: Project C10/K20 Transplant
Just installed dual fans and a fan shroud. Wired the fans to run on low speed/ high speed based on a BMW temperature switch. Mounted the relays for the fans and clutch safety switch in a waterproof relay box off of Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
08-11-2021, 10:37 AM | #77 |
landarts
Great work on the truck, read the entire build thread and really like how it all came together and choices made. Again great job!
Was there any modification needed to make the motor work with the manual transmission?
71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 69 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
10-04-2021, 02:07 PM | #78 |
Nope. Just make sure you have a matching clutch/flywheel combination. Everything bolted in fine. Since this is a one-piece rear seal motor, the correct flywheel is needed.
10-21-2021, 10:09 PM | #79 |
I love how your truck turned out, great job!!!!
07-15-2022, 04:52 PM | #80 |
Recent update to the project. Re-sealed a junkyard pulled 2005 LQ4 6.0 LS, added a mid-80's bell housing and hydraulic clutch. Ended up having to widen the original crossmember to clear. Best upgrade so far...
