04-05-2021, 03:21 PM | #1 |
72 C-20 Help
Sorry forgot my picture what am i missing on my Q-jet carb im not hearing the back 2 barrel's opening up when i mash the gas any help and pictures appreciate you guys Saddletramp
04-05-2021, 04:10 PM | #2 |
Re: 72 C-20 Help
Your choke is partally closed. It must be fully open for the secondary throttle to open.
George |
04-05-2021, 04:18 PM | #3 |
Who Changed This?
Re: 72 C-20 Help
Try pushing the choke plate all the way open (engine off!). Then open the throttle and watch the linkage on the driver's side to see if the secondary shaft rotates. If not, it's possible that the choke link isn't releasing all the way. Also make sure that the fast idle cam drops all the way down when you are holding the choke open. That's the lever right next to the body of the carburetor, inside where the vacuum pull-off linkages are. Also, make sure that the choke pull-off works. The top linkage prevents the secondary air valve from opening with the choke closed. That is the top link that is attached to the choke pull-off.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 04-05-2021 at 04:23 PM. |
04-05-2021, 04:26 PM | #4 |
Mr. Cheyenne
Re: 72 C-20 Help
The left side of the photo is cutting what I am looking at but it looks like the vacuum coming off the passenger side of the cab is going into a "T" that is also connected to the manifold vacuum? That can't be right?
my understanding (which could be wrong) that goes to the charcoal canister that is next to the battery (assuming you have have 3 port fuel pump and EEC Tank).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-05-2021, 05:52 PM | #5 | |
Who Changed This?
Re: 72 C-20 Help
04-05-2021, 06:24 PM | #6 |
Re: 72 C-20 Help
yes sir,all good info,the secondaries won't open unless the choke if off,and you don't need the nut on the air cleaner stud way down at the top of the air horn.the wingnut on top holds it all together.the nut might get in the way of the secondary metering rod hanger lifting up and allowing fuel to flow to the secondaries.
04-05-2021, 07:10 PM | #7 |
Re: 72 C-20 Help
Your picture is not showing the left side of the carb. Have a helper press down on the gas pedal and take a picture to see if your throttle linkage is opening all the way.
