07-22-2019, 09:02 PM | #51 |
Re: No Limit 63-72 Rear Shock Kit
Ok so I know I probably missed it but what's the advantage (if any) of relocating the shocks? I mean it looks cool but do they function better? Also would a monromatic stock replacement work with this as if I do end up doing this I don't want to replace the shocks I just bought. And is it only for lowered trucks or does it work on stock ride height vehicles
07-22-2019, 09:31 PM | #52 |
So. Does not work with porterbuilt rear trac bar.
I called and asked. Rob said it would. Posted via Mobile Device |
07-23-2019, 09:06 AM | #53 | |
Re-designing the way the shocks mount and react, and allows for a longer shock even with a lowered truck. Mounting behind the axle (on a T.A. suspension) increases the wheel rate of shock, and therefore quickens the shocks reaction time to the suspension. Having the shocks wider apart helps to stabilize the axle motion as well as the roll rate of the truck. Yes, you can use this with a stock height truck. And, yes, we have the correct part #'s for the monroe-matic shocks based on ride height of the truck.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
07-23-2019, 09:06 AM | #54 |
We have had a few customers do this, no one has reported any fit issues.
07-23-2019, 10:45 PM | #55 |
Please pm me with a price to relocate with stock ride height and shocks
02-23-2020, 02:37 PM | #56 |
How does this setup work with gas tank being relocated?
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt 01 Pontiac Trans Am WS6 |
02-23-2020, 04:25 PM | #57 |
With the gas tank being relocated as below, I would think the tank would need to be dropped to access the upper shock mount. This is not my truck, but one I had saved. I don’t think the tank would interfere with the brackets however. As you can see you still have access to swap shocks easily if the need should arise. The bracket would be more difficult to remove with the tank in the way.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
02-23-2020, 05:33 PM | #58 |
Old member
These will not work with PB trailing arms though. I have called and even asked if they would custom make me a set that would and was told no!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-27-2020, 09:53 PM | #59 |
I think I'll be doing this mod when I swap out my rear diff with a rebuilt posi unit, hopefully in the next few months. My fuel tank has been relocated, and I can't get a wrench or socket between the tank and the frame rail. I also don't want to drop the tank as getting the fuel filler hose onto the tank was a real chore. To gain access for the brackets, I may drill a couple of holes on the lower frame rail flange beneath the bracket location, and connect the holes with a cutoff wheel to make some slots for wrench access.
Thanks Andy, for the pics and info.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
06-13-2020, 03:04 PM | #60 |
can I use these with my ridetech rear shockwaves?
05-03-2021, 02:59 AM | #61 |
I wonder if this would improve the ride quality. My 68 Chevy C10 is lowered 6 inches in the rear.
