01-04-2015, 12:48 AM | #1 |
Transmission question
I have a 70 c10 with a 350SB and a T400 tranny. I put in a new torque converter when I put in the tranny. Prior to install I put in 2 qts of oil in converter. After install I put in an aditional 10 qts in tranny. I started the truck and put it through all gears a few times. Now when I put it in gear and hit the gas, the tanny feels like it is slipping. Any advice on what I might be doing wrong and how to fix it? Thank you all for any advice.
01-04-2015, 01:07 AM | #2 |
Cluster King
Re: Transmission question
Do you have the correct dip stick tube and stick for the trans? Are you checking the fluid level when the engine is at operating temp?
Make sure you have enough fluid in it. It sounds like you have 12 qts total. Does the trans have the deep pan? They hold an extra 3 qts. What torque converter did you buy? What is the stall speed?
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-04-2015, 09:03 AM | #3 |
I am replacing the engine and getting ready to put the turbo 400 back in , while cruising this site I ran across your post , How much fluid does it hold?
I posted a picture of the engine . |
01-04-2015, 04:02 PM | #4 |
What's the best way to go about it when you add the fluid to the dry tanny? How many times do I need to shift through each gear? I also noticed fluid leaking from the pan. Is that an indicator of something?
01-04-2015, 04:57 PM | #5 | |
After putting as much fluid as possible in the TC, start out with about 5 quarts in the pan then start the engine then add one or two more. Check for engagement then continue to fill until it registers on the dipstick up to the "add" mark. Then, run it through all the gears and add again to the "add" mark. Then, drive it until the fluid is completely warm and if necessary add fluid to the safe range on the dipstick. I like to see the fluid to the "add" mark when cold then after warm it will expand into the safe zone where you want it. New trans fluid is hard to see if it is leaking from a higher spot and will appear to be coming from the pan. That's not to say the pan is not leaking, but to say you need to confirm it's not coming from above. If you cannot see wet fluid above the pan, spray the trans case with brakleen and let dry. Then, spray foot powder on the case to make sure fluid is not coming from above and actually from the pan. |
01-04-2015, 05:12 PM | #6 |
Sounds like you overfilled it. What's the dipstick show running in neutral?
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
