01-23-2023, 02:51 PM | #1 |
Is there supposed to be a bolt spacer for the 400 TH fluid filter
1971 400TH, I found my filter without one.
Boy, long ago I asked this question and don't remember the answer. I can't even find the thread. I recall a spacer isn't used for this application or unnecessary, which might explain why I didn't mention one in my assembly guide. Anyway, with or without a spacer? Also, is this considered a deep pan? Other should the pick up tube install into the transmission's intake hole with one or two O-rings? Appreciate it, thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-23-2023 at 04:01 PM. |
01-23-2023, 02:59 PM | #2 |
Re: Is there supposed to be a bolt spacer for the 400 TH fluid filter
It’s been a long long time since I’ve fooled with those.
I do remember (the filter) it is floating. Now whether it has anything else besides that bolt ? I don’t remember. Sorry I can’t help anymore than that
01-23-2023, 06:15 PM | #3 |
Depends on the depth of the pan. With the bolt you are showing, the pan is only about 1-1/4'' deep. The longer bolt and spacer takes a pan about 2.5'' deep. The deeper pan also takes a different intake plastic with an O ring on each side IIRC
01-23-2023, 07:26 PM | #4 |
no there is no washer for that bolt. The filter is a loose fit and just floats around on that bolt.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-23-2023, 07:32 PM | #5 | ||
https://www.youtube.com/watch?v=S8OSBb9TB80&t=20s
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-23-2023 at 08:20 PM. |
