03-16-2021, 11:14 AM | #1 |
Re: Heard some bad things about CPP.
Yep! I buy CPP stuff from Summit - they have great service and an easy return process.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
03-16-2021, 09:22 PM | #2 |
Junior Member
To everyone,
I have done nothing to the stock rear end except removal of the factory drums and replaced the shocks. I am restoring this truck to just be a cruiser. No drag racing, no autocross and I do not need race stuff. Just wanting to upgrade to better brakes. I do not think I need baer/wilwood stuff. After reading ya'lls replies I decided to get a rear disc brake kit from Summit (CPP) for the free shipping and the easy returns mentioned. Not the big brake kit either just 11 inch rotors. I hope it will perform to meet my needs. If this kit works will I plan on getting the one for the front with the new master and booster. Also replacing all the brake lines also. I do plan on dropping about 3 or 4 inches in rear....2.5 in the front with drop spindles. If anyone has bought the CPP front disc brake kit and what luck you had with it and if I need to look out for something any help would be appreciated. As a side note.....I have a lot of drum brake parts (new) I would like to sell for a good price. Thank you, Mike M |
03-17-2021, 08:00 AM | #3 |
I wouldn't install disc brakes on the rear axle first . They will lock up tighter than Dick's hat band . The weight of the truck is in the front that's where your breaking force comes from and why stock trucks used front disc brakes and drum rears . Use the rear drum brake parts you already have and buy the front disc brakes .
Start a new thread to get info on improving your brakes . Now that this thread is in vendor review area it won't get as much attention .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-17-2021 at 08:07 AM. |
03-17-2021, 09:29 PM | #4 |
Junior Member
Oh, I will be doing the front brakes before its out on the road, probably if this kit works out good and I like the fit and quality will do the front in about a month. Wanting to redo the whole brake system. The truck needs more work to be out on the road. Dash wiring harness and Wiper Motor work among them.
Thanks for the info. Mike M |
03-22-2021, 05:41 PM | #5 |
I had a few of their Chinese products on a 55 Chevy car. I'd say 50% of them were OK, the others acceptable to poor. Ball joints that came with their upper control arms had cracked dust boots. They did send me another pair, but I ended up using Moog ball joints. The control arms themselves were nice, except they just barely mated with the rubber snubbers on the frame.
The car also had one of their 500-series steering boxes. It worked fairly well, but the optional aluminum cover that came separately had the world's softest chrome bolts. Made me wonder what the steering box internals were like. Had I kept the car, I would have replaced it with one from Borgeson. On another note, I second the Grump. Rear drums work great on these trucks, and unless you use a high quality disc kit from a vendor like Wilwood, I doubt you'd feel any improvement over drums. My 69 has 5-on-5 axles with Wagner shoes and the heavier 71-72 finned drums, so they can handle more abuse than the 69's non-finned drums. Not that I ever really need that!
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-25-2021 at 10:08 AM. |
03-24-2021, 09:56 PM | #6 |
Junior Member
Thanks for all the info on this.
I do have a question about wheel studs. Have to use longer wheel studs for the disc brakes.....and I took one of the original ones out. It has a "186" on it and the ones that came in the kit is longer and I am supposed to use them. It has a "259" on it. Is this related to them being longer that the original's...or is this related to strength of the bolt? They are both grade "8" bolts, having the six lines on them. Thanks for everyone help with my questions. MikeM |
