Old 10-01-2021, 06:08 PM   #26
62 Barnfind
62 Barnfind's Avatar
Re: 1961 Apache
Originally Posted by 62c30 View Post
Attachment 2099035
front end is in, cut down the engine perches. hopefully set the engine in next week or two.
What engine mounts are you using and where did you get them? Looking to do a V8 swap in the future.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 10-01-2021, 07:01 PM   #27
62c30
Re: 1961 Apache
I used a complete square body front end and used the engine perches too. I cut the tops off and welded a plate onto them cause there is a gap between them and the frame that would need a spacer. The motor mounts are stock replacement with dirty dingo adapter plates
62c30 is offline   Reply With Quote
Old 10-14-2021, 10:35 PM   #28
62c30
Re: 1961 Apache
Back from blasting
Old 10-14-2021, 10:37 PM   #29
62c30
Re: 1961 Apache
As bad as it looks the cab came out better than I thought it would
Old 10-15-2021, 09:17 AM   #30
cwcarpenter98
cwcarpenter98's Avatar
Re: 1961 Apache
Dadgum, looks like the inside of the roof was a mouse house
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 10-15-2021, 09:48 AM   #31
62c30
Re: 1961 Apache
Yeah it was, when I took the outer panel off above the windshield it was like a waterfall.....
Old 10-19-2021, 09:36 PM   #32
62c30
Re: 1961 Apache
Started fixing the inner roof
Old 10-19-2021, 10:41 PM   #33
SkinnyG
SkinnyG's Avatar
Re: 1961 Apache
That's a lot of air gap. REALLY control your heat so it doesn't shrink too much when final welding. Tack, planish, grind it, then do the next tack.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-25-2021, 05:42 PM   #34
88Stanger
88Stanger's Avatar
Re: 1961 Apache
Exactly.... i had to do 1/2 this amount and it was a pain in the butt, very time consuming.. but worth it in the end....
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
