08-02-2021, 09:57 PM | #476 |
Re: What did you do yo your truck today??
I washed it ?
08-05-2021, 03:00 PM | #477 | |
Picked up a steering box at the junkyard for the '93.
08-05-2021, 04:55 PM | #478 |
I washed this one , clay bar then waxed , still looks good for original paint !!
08-05-2021, 07:27 PM | #479 | |
Cool Volkswagen.
08-05-2021, 10:22 PM | #480 |
Thanks , that was our father son project , Original paint AC Caddy , may get deleted ??
08-05-2021, 10:26 PM | #481 |
not sure how that happened , ??
08-05-2021, 10:31 PM | #482 |
Started this one today sitting since 2019
08-06-2021, 12:19 AM | #483 | |
I have to resize my pictures or they post upside down.
Did you do an engine swap? My brother had one and he put in a bigger engine. I think a VR6?
08-06-2021, 10:03 AM | #484 |
yes we did a 1.9 diesel with bigger turbo , tweaked pump , about 160 hp , fun to drive , rolls a little coal !
08-06-2021, 07:07 PM | #485 | |
Nice. Looks like it's in good shape.
08-15-2021, 02:29 PM | #486 | |
I changed the seals on the power steering high pressure line and the fitting that screws into the pump. Started leaking after I put on the used pump.
08-15-2021, 06:28 PM | #487 |
wash and a drive
08-22-2021, 10:26 PM | #488 |
Replaced the power steering pump. Also, the flowmaster that I ordered from 4wheelonline arrived today. I'm planning to install it tomorrow.
08-23-2021, 07:21 PM | #489 | |
Front brakes again.
08-28-2021, 10:29 AM | #490 | |
There are 10 kinds of people in the world: those who understand binary and those who don't. __________________ 1985 C20 Scottsdale 350/SM465 1978 C10 Silverado Big 10 3 on the Tree (sold) |
08-29-2021, 12:09 PM | #491 |
washed and waxed
1995 k3500 cclb srw 6.5 turbo diesel. The lessons that hurt are the lessons that teach. There is always a price to pay. You are free to make any decision you want. You are not free from the consequences. |
08-29-2021, 07:50 PM | #492 |
Put Rear Firestone Air Bags, Compressor, 5gallon Tank all Wired And put Extra Air Fitting To plug line To Check Air Pressure
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
09-01-2021, 04:18 PM | #493 | |
Picked up a center link at the junkyard for the '93. Non wearable part seems to be worn out.
10-08-2021, 06:12 PM | #494 | |
A/C compressor locked up today.
10-16-2021, 02:10 PM | #495 | |
Driveshaft center support bearing came out of the mount again. This time I'm gluing it to the rubber.
10-28-2021, 12:44 AM | #496 | |
Changed the EGR valve.
10-29-2021, 12:34 AM | #497 |
Rear dana 80 pinion seal in my 3500-HD truck . She was worn out and leaking at only 83,300 miles .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-01-2021, 01:29 AM | #498 | |
I repositioned the plug wires on the '99, it was misfiring and I could see the residue from where they were arcing. I'll pick up new wires soon. I also exchanged the lifetime warranty plug wires on the '93 as it was misfiring too.
11-09-2021, 06:50 AM | #499 |
Been needing tires for the 'Burb. Friday I picked up a screw at Lowes that took it down flat while loading up cinder block... Argh! I got a closer look at that flat and decided to pull them all and install the wheels and tires off my '72, which will be sitting till spring at least. I like the look but it's temporary. Although the same size tire (285/75-16) the 8" rims cause tires to rub. I'll get the old tires off the 7" Accurides and mount the better tires. First I want to paint those wheels argent for a closer to factory look. I had them that color originally on my old '92.
11-13-2021, 07:35 PM | #500 | |
Pulled the distributor from the '99 to check the gear for wear. Seemed fine. I need to find a scanner that reads CMP retard.
