Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-23-2021, 02:24 AM   #1
68ls1
68ls1's Avatar
Tach at 3,000 rpm at idle
We have just installed a Holley Terminator EFI set up with Holley Hyperspark distributor, ignition coil and CD ignition box on SBC in my C10. The tach (5,000 rpm add on restoration one in dash) is now showing 3,000 rpm when idling, read out on Holley display is correct.
Anyone encountered this problem? Where to look?
thanks
68ls1 is offline   Reply With Quote
Old 08-23-2021, 08:44 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Tach at 3,000 rpm at idle
I'm assuming this is your system? On your Tach, who makes it? Do you have a link?
Old 08-23-2021, 08:59 AM   #3
68ls1
68ls1's Avatar
Yes, that looks like the system.
I believe this is the tach, was in truck when I purchased, https://www.brotherstrucks.com/1967-...tinfo/TACH772/
Old 08-23-2021, 02:51 PM   #4
Custom 68
Custom 68's Avatar
I'm sure this is different but when I did my ls swap I used the GM factory computer and my aftermarket tack had to be switched to 4cyl mode to read correct. This may be apples to oranges but figured I would throw it in.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-25-2021, 10:57 AM   #5
biketopia
Big difference in terminator or the sniper system, terminator has an external ECM, sniper it's all internal to the throttle body, which do you have? I have a sniper system with the hyper spark distributor, a 6al box, and blaster ss coil on my camaro that I'm tinkering with until I swap it all into my c-10. My autometer tach and handheld read identical, the tach needs to be hooked to the brown wire on the sniper. If you have terminator set up that may change.
https://www.efisystempro.com/efi-pro...gnition-wiring
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 08-25-2021, 05:22 PM   #6
68ls1
68ls1's Avatar
I am running a Terminator X Max Stealth
https://www.holley.com/products/fuel...parts/550-1013
We tried swapping wires, adding diodes etc without any luck.
On advice from gauge specialist we have pulled tacho, and sent to him. He advises there are two kinds of signals, a coarse signal and a fine signal which the Holley supplies. We will see how it goes.
In better news my temp gauge which would not come off low is now reading more accurately?
Old 08-26-2021, 08:04 AM   #7
biketopia
Ahh ok, the terminator is nice ECU set up. It should do what ever you need it to. There are tons of settings in the input output sections was there maybe something you needed to adjust using the laptop software not the handheld.
