Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-09-2020, 02:34 PM   #1
KMC3420
KMC3420's Avatar
Cab floor replacement order
Hello, I am to the point where I will be replacing my cab floor over the next few weeks. I have the cab braced and have removed the outer rockers. Also, I have drilled all of the spot welds at the rear cab wall. I still need to remove the spot welds on the footwell flange. I am wondering for anybody who has done this before did you pull the floor and align the new floor to the old A and B pillars or did you replace the lower A and B pillar sections first and then install the new floor? Below are the pieces I am needing help with replacing before or after floor install. Thanks.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 07-09-2020, 08:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Cab floor replacement order
my AD truck is gonna need all these parts replaced...so it got me thinking about this..
I think id get the rockers in place and make sure the doors work properly
hopefully you have it x-braced so the doors still open and shut
I think id do the floor 1st and then all the other panels.. but that's just me..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-09-2020, 09:49 PM   #3
KMC3420
KMC3420's Avatar
Yep the cab is tied together front to back and side to side. I plan on removing floor, lifting cab straight up and rolling new floor under, then lowering cab. I do have good enough metal to fit the new floor to the existing lower A/B pillars. I think I will follow your suggestion since getting the new floor to fit the existing panels will be the biggest challenge. I don’t anticipate it just going in and lining up perfect. So, if I leave my existing bolt hole locations as my guide to align the new floor will probably be best. Thanks sir. Just thinking out loud.
Keagan
Old 08-18-2020, 10:30 AM   #4
May70
May70's Avatar
Hi hump floor or regular?
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 08-18-2020, 04:39 PM   #5
KMC3420
KMC3420's Avatar
Low Hump floor, but will be using a bolt in High Hump.
Keagan
Old 08-18-2020, 09:35 PM   #6
May70
May70's Avatar
Yeah, then you will definitely want to track my thread. The stamp has some issues, the inner rockers do not drop down low enough, they are too high by about 3/8". Ill post the details when I get it buttoned up. I took measurements on 3 factory cabs and they all showed that the stamp does not drop the lip on that inner rocker far enough.
You will want to leave the pillars in place until after your floor is in (if you need to do any rust repair). Draw a line with a paint pen across the back of the cab right where your floor meets the cab wall. You can use that line to make sure your new floor is sitting at the proper level across the back. Use those bolt holes on the original front pillars and the firewall lip.
Dont even attempt to do this with the outer rockers on. Brace it up really good and make sure you can still put doors on. If you look at my bracing, I would add a few braces up to the roof to keep that distance the same.
The way the floor fits up onto the fire wall lip you have to put the front up into the lip first, then raise the back of the pan up into position. You will need two helpers, one for either side of the pan and for you to guide it into place.
Old 08-19-2020, 01:03 PM   #7
KMC3420
KMC3420's Avatar
Thanks May. I am currently remaking the firewall lip and getting the patches fit/welded with the original floor in. I will go back and look at your thread for review. Thanks.
Keagan
Old 08-22-2020, 04:13 PM   #8
jrusher
Here’s a few pics of my 65 I did two years ago . Brace cab real good . A cart is nice to roll cab around on . Then I did kick panels , toe boards etc . Like others have said you will have to add 3/8” of an inch give or take to inner rocker area . I didn’t know this and fought with my rocker fitting and door/fender alignment what a waiste of time. My doors are very tight to rocker where I should of lowered rocker more and added that material in on inner floor . When I did the wife’s 61 a year later I seen a post where guys were adding material to that inner floor/rocker area and things line up nice. Live and learn
Have fun. I have a 72 that is going to get same treatment here soon least I’m getting quick at it now lol
jrusher is offline   Reply With Quote
Old 08-22-2020, 04:27 PM   #9
jrusher
Had to swap a different roof skin on as well . Was a lot of work on that cab but sure Is a good feeling when your done all the metal work and putting it all back together
Old 08-23-2020, 11:05 AM   #10
KMC3420
KMC3420's Avatar
Thanks Jrusher, the pictures do help. Once I get moving a little quicker I will post some progress here. Cutting and fitting toe board patch panels has slowed me down, and other house projects.
Keagan
Old 10-11-2020, 10:58 PM   #11
KMC3420
KMC3420's Avatar
Floor is out. The hardest part was getting the floor out with cab corners still intact and not cut any. The front firewall pieces keep the floor from being able to tilt down. I will be cutting those at an angle when putting my new floor in.
Passenger side:
Driver side:
Pile of ....
Keagan
Old 10-11-2020, 11:03 PM   #12
mongocanfly
I really wish you had X braced those door openings before you started cutting….hopefully itll work out for you
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-11-2020, 11:13 PM   #13
KMC3420
KMC3420's Avatar
I measured the door openings after removing the floor, A pillar to B pillar and it was the exact same measurement. Hopefully have it in by this weekend and can hang the doors to verify then put the lower A/B pillar patches.
Keagan
Old 10-11-2020, 11:16 PM   #14
mongocanfly
gotcha...hanging the doors will be good before you weld it all up
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-11-2020, 11:22 PM   #15
KMC3420
KMC3420's Avatar
Agreed. I should of X braced but got a little ahead of myself but have lots of measurements wrote down and will get as close as possible to those. Makes me a bit nervous!
Keagan
Old 10-12-2020, 06:11 AM   #16
Richard2112
Richard2112's Avatar
Great thread. Though I don't need a floor, I'm keeping an eye on this
Richard2112 is offline   Reply With Quote
Old 10-12-2020, 10:57 AM   #17
KMC3420
KMC3420's Avatar
Hopefully you will see a happy ending!
Keagan
Old 10-25-2020, 12:18 PM   #18
KMC3420
KMC3420's Avatar
The cab floor is in, and the door opening measurements are the same as they were. That was my biggest worry. The bolt holes are close but will need some reaming. The front edge passenger side has the biggest gap and will require a cut and a pie shaped patch. Overall really happy with the fit. Will get the doors on and check final fit. The back of the cab is bolted tight to the existing brackets but the front of the floor is not attached at all. I put vertical stops and as you can see the new floor hits the stop.
Keagan
Old 10-25-2020, 12:21 PM   #19
KMC3420
KMC3420's Avatar
More pics.
Keagan
Old 10-29-2020, 08:27 PM   #20
sduckworth13
sduckworth13's Avatar
Nice Work! I loved the Tabco panels, probably the best fitting panels I’ve used.
Scott
sduckworth13 is offline   Reply With Quote
Old 10-29-2020, 08:46 PM   #21
KMC3420
KMC3420's Avatar
Thanks, gonna hang doors tomorrow and make sure they clear the rockers fine and then start welding the floor in. I am looking forward to the tabco panels. Just from eye balling them they appear to be very close. How did those Ridetech shocks work out for you?
Keagan
Old 10-29-2020, 10:06 PM   #22
sduckworth13
All I can suggest on the doors is put a jack under the door, they will wear you out fitting the rockers and getting the door gap right. The shocks were nicer than the stock ones, but I wouldn’t buy them again. Kinda pricey for just OK shock performance. I was expecting a lot more cushion out of them.
Scott
Old 10-29-2020, 10:18 PM   #23
KMC3420
KMC3420's Avatar
Yes, that is a great suggestion. I am going to try and use my engine hoist to hold the door up and get a few bolts in. That’s if my son can’t get them in with me holding it. I don’t have the windows in the doors currently so that should help. I am on the fence about getting those shocks for the rear. I have Ridetech HQ’s for the front, but might go a different route for the rear. They are pricy.
Keagan
Old 10-29-2020, 10:41 PM   #24
sduckworth13
That sounds like a great idea!
I had tough time, but I finally got them lined up right. I didn’t settle for anything except a nice click when they shut.
Scott
Old 10-30-2020, 08:12 AM   #25
KMC3420
KMC3420's Avatar
Your body line looks nice and straight from the door to cab corner. What is the gap between your door bottom and top of the outer rocker? I was thinking maybe the thickness of a paint stir stick, the wooden ones.
Keagan
