Old 10-05-2020, 11:22 PM   #1
thedudeabides86
Active Member
thedudeabides86's Avatar
To have heat, would be nice.......
Good evening, gearheads!
Iíve got a Ď72 C20 with no heat. It does not have factory air. Iíve had this truck for 25 years and never has the heat worked. Where would you start to figure out the problem? I just replaced the slide switch assembly and when I had it started a couple days ago I played with the switches and had no fan or air pushed out so the blower motor might be bad? Or maybe fuses? Iím still learning the way to fix things on this that Iíve never had to fix before. Any suggestions would be appreciated. Thanks everybody!!
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 10-05-2020, 11:27 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: To have heat, would be nice.......
Does the heater core leak? are the hoses even hooked up to it? or is it bypassed?
Start with the heater core, make sure its in good shape.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-05-2020, 11:28 PM   #3
68 P.O.S.
Do you recall anything from the PO about the heat when you bought it? My limited experience with these trucks is the heater core is usually bad. As you said, it could be a fuse, bad blower motor. Deteriorated vent lines. How's the electrical looking down there?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-05-2020, 11:29 PM   #4
Getter-Done
Getter-Done's Avatar
Pictures would help.
I think the first thing I would do is Pull the fan motor and bench test it.
When you pull the fan out look for Critter Nest also
84 Chevy K-20
paypal.me/Dwayne67CrewCab
Old 10-06-2020, 12:15 AM   #5
gmc684x4
Are the heater hoses swapped ?
I had a service van years ago went to the shop many times still no heat i got stuck with it on a long cold road trip reveresed the heater lines better flowing heat
That said blower motor needs to work heater door needs to be open vent tubes needs to be in place
How much leaves and trash has built up in the cowl area ?
gmc684x4 is offline   Reply With Quote
Old 10-06-2020, 01:38 AM   #6
pjmoreland
pjmoreland's Avatar
There should be a ground wire attached to the blower motor housing on one end and to one of the heater box screws on the other end. Assuming the ground wire is good, you could unplug the power wire from the blower motor and connect a test wire directly from the battery + terminal to the blower motor power terminal to see if the motor will spin. Don't leave this wire connected if you don't hear the motor start to spin, as there could be a short inside the motor, and this test wire is unfused.
The blower fan could be totally clogged with leaves.
pjmoreland is offline   Reply With Quote
Old 10-06-2020, 07:29 AM   #7
BigBird05
Start with the basics. If the heater hoses are connected, do they both get hot? If not you have a coolant flow problem.
BigBird05 is offline   Reply With Quote
Old 10-06-2020, 09:51 AM   #8
BRL
BRL's Avatar
Iíve got a Ď72 C20 with no heat. It does not have factory air. Iíve had this truck for 25 years and never has the heat worked...
You sound like me, (that's a complement) and some of the little projects I've put off on my truck forever.
But even if the fan itself isn't running, shouldn't some heat still be coming through the vents at cruising speed if the switch is slid to the hot position and everything else but the fan is working properly?
BRL is offline   Reply With Quote
Old 10-06-2020, 10:05 AM   #9
LockDoc
The Original Thread Killer
LockDoc's Avatar
Not if you have something like this in the heater box.... It's a common occurrence.
LockDoc
Leon
Old 10-06-2020, 10:21 AM   #10
franken
Jump across the fan switch contacts before tearing things apart...
Old 10-06-2020, 10:30 AM   #11
BRL
BRL's Avatar
LockDoc
Yea, once I opened up a kick panel vent while going 50 and my cab became an instant movie theater pop corn machine with little cotton ball sized fluffy stuff flying everywhere!
Dang vermin!
Old 10-06-2020, 07:31 PM   #12
thedudeabides86
Active Member
LockDoc
I'm guessing the silver piece in the picture is the heater core? I've never torn into this myself so I'm in unchartered territory. I'll post the pics of where I'm at in the thread.
The Dude abides.
Old 10-06-2020, 07:58 PM   #13
thedudeabides86
Active Member
I remember back in high school 23 yrs ago, a coworker wired up a variable speed switch to blow heat but that's been removed. I noticed an orange wire with a boot on the firewall that wasn't plugged in. I tried that. but it didn't make anything work. Here's pics of where I'm at. You'll see the orange wire that's not plugged in just off the center of the photo.
The Dude abides.
Old 10-06-2020, 08:18 PM   #14
LockDoc
LockDoc's Avatar
Yes, but that is an A/C truck, heater only is easier. The orange wire is the power for the heater. Turn the heater control for the fan all the way on and see if there is 12 volts to that wire.
LockDoc
Leon
Old 10-06-2020, 09:04 PM   #15
LockDoc
LockDoc's Avatar
Looking at your under dash picture again it looks like your connector for the blower circuit is not plugged in to the switch on the right side of the heater control panel. In the first picture below you can see where the connector is supposed to be plugged in. the other end of that harness plugs into the blower motor resistor located on the top side of the heater box.
LockDoc
Leon
Old 10-06-2020, 09:14 PM   #16
thedudeabides86
Active Member
LockDoc
I unplugged those to see where to start tearing things apart. They were plugged in before I started. Sorry, I shoulda mentioned that.
The Dude abides.
Old 10-06-2020, 09:17 PM   #17
LockDoc
LockDoc's Avatar
OK, no problem there then.
LockDoc
Leon
Old 10-07-2020, 11:12 PM   #18
thedudeabides86
Active Member
So, update on the heat issue. It may not be that I don't have heat, it's that my blower motor doesn't power when the truck is running. We used a jumper from the positive post on the battery to the blower motor and it kicked on. So, where do I go from here? Is the connection at the ignition bad? Bad wire to the fuse panel? Uffdah.
The Dude abides.
Old 10-08-2020, 12:13 AM   #19
pjmoreland
pjmoreland's Avatar
Power for the heater motor comes from the ignition switch, then through the fuse panel on a brown wire on that connector that was unplugged in one of your photos (plugs into heater control switch). Do you have 12V on the brown wire when your ignition is in the run position? Maybe a bad fuse?
Old 10-08-2020, 05:00 AM   #20
toolboxchev
The Heater issues on these trucks can be quite extensive. GM never wired the trucks properly.
The Fan itself, on high, can pull too much amperage and cause the under dash harness to burn up ignition switches, wiring, heater switches, and multiple other items.
MAX draw for that wiring and related components for the heater only trucks is either 10 or 15 amps.
toolboxchev is offline   Reply With Quote
Old 10-08-2020, 05:06 AM   #21
toolboxchev
A Never Popped kit from Classic Industries is a great upgrade for the levers in heater controls.
Easy Peasy to install. I did have to get some very small nuts and bolts from Ace Hardware due to some sheet metal screws stripping out.
Old 10-08-2020, 07:21 PM   #22
thedudeabides86
Active Member
I searched Classic Industries for Never Popped Kit and didn't find anything. Can you post a link?
The Dude abides.
Old 10-18-2020, 12:00 PM   #23
thedudeabides86
Active Member
Re: To have heat, would be nice....... Updated
Sooooo, update on the reason I never had any heat in this truck for 25 years.
Are you all sitting down? Good.
The fuse panel has a fuse spot marked "AC" which is 25 amps. Anyone know where this is headed? I put a fut in this slot and the blower motor fired right up and I had heat! This truck does not have AC so I figured I never needed a fuse is this spot. Who'd have thought, it was a simple fix like a fuse. So, that was easy!!
Sabin
The Dude abides.
Old 10-18-2020, 12:06 PM   #24
Getter-Done
Good Deal
Glad you found the problem.
84 Chevy K-20
Old 10-18-2020, 03:05 PM   #25
HO455
HO455's Avatar
Excellent! Now the dude will be warm as he abides.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
