Old 02-20-2015, 05:32 PM   #1
grad70
Exhaust ideas for 6.0
Hello Fellow Members,
I have recently got my 6.0 ls swap to start the last weekend in my 1970 C10 2wd long bed. I am really disappointed that I did not take many pictures at all during the process (really drawn out process). I will post pics of the truck and a video of the truck running with only Doug Thorley headers. I still have plenty of work to do it, but I managed to hook up enough to hear her run (great motivation to continue).
Back to the topic, I want to know and hear some of your exhaust set-ups that you have plumbed into your 6.0's! It will be a little while before I plan on getting the exhaust installed.
grad70 is offline   Reply With Quote
Old 02-20-2015, 05:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Exhaust ideas for 6.0
I don't have mine that far along yet but welcome to the board from another Iowa boy. And yes, we want pictures...
LockDoc
Leon
Old 02-20-2015, 05:53 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
I don't really have a decent idle clip, but it's a cammed LQ4, longtubes, dual 3" stainless exhaust with Magnaflows, no x or h pipe, dumped at the rear axle.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-20-2015, 07:01 PM   #4
grad70
LockDoc
The truck itself is not the flawless body like you see from everyone else on this site, but I wanted to add a reliable engine and tranny to drive her all over the place. Just got a front bushing/joint kit, static drop kit, front disc brakes, rear drum rebuild kit from ECE last week that I need to start on.
Thanks for the welcoming, i have been a member for a while but with very little posts (too much reading and learning). Only way i was able to get through most of my issues was to read through these forums for hours at a time!
PS. I just recently moved back to SD, thanks for reminding me to update that.
Old 02-25-2015, 03:49 PM   #5
grad70
Pics from when I first brought the truck home.......
Old 02-25-2015, 03:50 PM   #6
grad70
Old 02-25-2015, 03:51 PM   #7
grad70
Old 02-25-2015, 03:54 PM   #8
grad70
Pic of the pickup before starting with the new 6.0 ls based engine. I don't take a lot of pictures and now I regret that fact.
Old 02-26-2015, 05:05 PM   #9
Justin@EntropyRad
Justin@EntropyRad's Avatar
the truck motors like to have an H or X pipe...more torque too
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 02-26-2015, 06:21 PM   #10
69gmcc10
69gmcc10's Avatar
According to the exhaust program I have, if your engine is a stock LQ4 and you have Doug Thorleys on it your exhaust diameter should be 2.75" to 3", you should have an H in the system 19.4" behind the end of the 2nd primary pipes and a muffler 38.7" back form the 2nd primary into chambered mufflers approximately 370 cubic inches in dimension. After the muffler it doesn't really matter what you do as long as you keep the diameter at least the same size as goes in it. I would personally go with 2.75" pipes because you will reach volumetric efficiency sooner and start creating power lower in the rpm range.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 02-26-2015, 06:56 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You won't find 2.75 as much at exhaust shops or parts stores as you might hope....at least not the "commercial" ones. The universal stuff is all sold in 2.5 or 3" for the most part.
The actual custom exhaust places, tubing companies themselves, and online you can still get 2.75". Just my random observation.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-26-2015, 07:30 PM   #12
69gmcc10
69gmcc10's Avatar
I 100% agree it isn't the easy way to do it, but I always finding my way down the path of doing things the hard way.
Old 02-27-2015, 02:23 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Or just run 3" pipe since bench flowing exhausts is still ballparking (just really good ballparking). Most setups wouldn't notice the difference, and since so few of these things stay stock intake/cam/heads you'll end up wanting the 3" anyway.
I'm not discounting your calc, which does offer a lab-ideal result. I just think that even with a program, there are factors that aren't being accounted for. Especially if I were considering a stainless system where cost is a factor, I'd rather build a 3" system I'm less likely to outgrow.
Old 02-27-2015, 05:42 AM   #14
grad70
I'm really happy that I have been receiving this information. Some time down the road I may look at swapping the cam, but for now I just want the thing running for me! More information is welcome as I still have a lot to learn and over research before making a decision!!
For some reason I am having issues with adding the video from my iPhone of the start up. Is there an easy way to do this?
Old 02-27-2015, 01:16 PM   #15
69gmcc10
69gmcc10's Avatar
I absolutely agree with you! The program does not factor in cost of materials, future engine modifications, or packaging. How in the world are you supposed to install a muffler in the middle of a cross member or equal length headers that allow service to spark plugs? The moment you change something the calculation changes. What I do find interesting in the program is that if you use shorty headers the program recommends 2.75" exhaust pipe, if you use long tube headers it wants you to use 3" pipe and the tri-Y calculation says to use any size between the two. I use it as a starting point and am more than happy to make accommodations for packaging.
Old 03-04-2015, 05:30 AM   #16
l92powered77
Hey that sounds really mean! , what intake you runnin?truck or vette. Post more specs on the ss. Tranny? Radiator and efans? Ecm Abd harness?
Monte SS LQ4 Burnouts.wmv - YouTube
l92powered77 is offline   Reply With Quote
Old 03-04-2015, 11:15 AM   #17
Wasted Income
Boosted Member
Thanks.
LS6 intake from a CTS-V.
4L80E with a 3600 stall
Ebay aluminum radiator that i welded bosses to, to mount a junkyard dodge intrepid dual fan to.
GM 0411 ecm tuned by me with EFI Live. Has a custom operating system for the nitrous. Harness was modded by Speartech years ago.
Turbo diesel
Old 03-06-2015, 09:06 AM   #18
solidaxel
solidaxel's Avatar
Here is a 78 with a 2.5 H pipe and walker muffs
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
