Old 08-03-2021, 04:36 PM   #1
QBRacing
Hoods & Hood hinges
So I have a 58 Apache here in NZ and while rebuiling it I discovered my cab is a late 57 (58 wipers dont mount up, hood hinges are bigger bolts closer together and water holes different.
My old hood hinges are poo, they were 58-59 hinges where the firewall holes were slotted and the hood never sat right cause you couldn't align them properly.
Knowing this I just bought some 55-57 Eddie Motorsport Billet Hinges which I immediately fitted. OMG they look so good.
While mounting them I thought the face where the hood mounts looked funny, but I just wanted to get them mounted... well I was right.
Im guessing the 55-57 hood has a step in the hood where it mounts to the hinge where the 58-59 is flat. I also measured the hole spaces and the 55-57 is narrower and offset where the 58-59 is wider and straight.
How do I fix this?
Can i simply get a set of the 58-59 hood mount bits from EMS and swap em out or do I now need to get a 55-57 hood as well.
I currently have some $750USD ornaments
QBRacing is offline   Reply With Quote
Old 08-03-2021, 04:38 PM   #2
QBRacing
Re: Hoods & Hood hinges
One pic with my old hybrid 58-59 hinge beside the new hinge
Old 08-03-2021, 04:52 PM   #3
mr48chev
mr48chev's Avatar
t's 1:49 PM on Tuesday afternoon =13:49 here so it may take a while until those who have the good answers get to a computer.
My ongoing truck projects:
Old 08-05-2021, 01:57 PM   #4
Patrat
Junior Member
I was planning to do the same thing and not aware the older hood was different,
Patrat is offline   Reply With Quote
Old 08-05-2021, 02:35 PM   #5
_Ogre
_Ogre's Avatar
i believe your gonna need to go all 58/9 and mount in the 58/9 location
the 57 hood is narrow at the front, the hinges are very different with the spring on hinge vs hooked to the inner fender
as far as the wipers, they should fit i don't believe any changes were made there
i added a couple pics of the 58/9 hinge, i'll leave it to someone else to post up a 55/7 hinge
shop air compressor timer
Old 08-05-2021, 03:24 PM   #6
QBRacing
I have the 58-59 hinges but they won't work as the firewall is a 55- 57 so the bolt spacing is wrong , that's why someone previously slotted to current ones which I slotted further trying to get them to fit bitter.
I am also not going factory hinges either, going with some billet ones.
I thought front parts were interchangeable , but I guess that's as a whole, guards and.hood and grill etc etc
I found a 55-57 hood which is being delivered today. My hope is that I can unpick the mount section at the rear of the hood and put that in my current 58-59 hood if that makes sense.
I can 100% confirm the wiper mounting and setup is different between the two as I had to return the Newport 58-59 and get the earlier 55-57.
Old 08-05-2021, 09:28 PM   #7
1project2many
This discussion comes up from time to time. Here's a very good thread. trucktony posted some detailed information and pictures covering some of the differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=522950
1project2many is offline   Reply With Quote
Old 08-06-2021, 03:00 PM   #8
_Ogre
_Ogre's Avatar
you'd probably be better off asking someone with a 58/9 cab to measure and template it for you, then use the 58 hinges
Old 08-06-2021, 07:17 PM   #9
carbuff382
carbuff382's Avatar
If you decide to part with the hinges I may be interested if the shipping isn't outrageous.
Thanks,
carbuff382 is offline   Reply With Quote
Old 08-08-2021, 02:50 PM   #10
Ghetto Fireman
Junior Member
Ghetto Fireman's Avatar
2nd in line for the hinges if you do indeed decide to sell. I was just about to buy a set for my 57.
Good Luck !
Mike
Ghetto Fireman is offline   Reply With Quote
Old 08-20-2021, 10:21 PM   #11
QBRacing
Sorry guys but sending the hinges overseas again isnt an option.
Just made a quick video about this issue and my resolve to fix it.
I have since unpicked the lower inside of the white 55-57 hood and have still to do it to the 58 hood but it looks promising.
Video here
Old 08-21-2021, 09:43 AM   #12
carbuff382
carbuff382's Avatar
No problem, and looks like you've got a solid plan of action to correct the issue!
