Old 12-28-2020, 10:06 AM   #1
superchevy
Got big-block?
superchevy's Avatar
70 short stepside 496/T400 aka "the emerald turd"
found this rusty, crusty, abused truck about 3 years ago...the cab, bed, front clip were laying in the mud...the frame was propped against a tree...paid $200 for everything...took 4 of us to lift the cab on the trailer as it was full of mud and a giant fireant mound...got it home and, inspired by Roadkill, through it together in about 5 months with mostly spare parts and some new...fun to drive now
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 12-28-2020, 10:07 AM   #2
superchevy
Got big-block?
superchevy's Avatar
Re: 70 short stepside 496/T400 aka "the emerald turd"
I will be posting the whole build pics soon.
build thread
build thread
Old 12-28-2020, 10:18 PM   #3
yuccales
yuccales's Avatar
I like short steppers! Not sure I'd call it a turd however. Your sig says you have 3 Sprints. Had this 75 for 22yrs. With out a doubt the most reliable, trouble free vehicle I've ever owned. I even liked the "economy rear axle ratio". 2:56 gears, no towing with that one! Looking forward to more build pics.
yuccales is offline   Reply With Quote
Old 12-31-2020, 10:02 AM   #4
superchevy
Got big-block?
superchevy's Avatar
that is a nice Sprint! mine are all project cars at the moment...I keep building trucks first, lol
build thread
build thread
Old 12-31-2020, 10:03 AM   #5
superchevy
Got big-block?
superchevy's Avatar
pic when I first dragged it home
build thread
build thread
Old 12-31-2020, 10:09 AM   #6
superchevy
Got big-block?
superchevy's Avatar
I got to work on the frame...used drop spindles/springs/front disks...rear springs/blocks...total of 5/7 drop
build thread
build thread
Old 12-31-2020, 10:11 AM   #7
superchevy
Got big-block?
superchevy's Avatar
braced the trailing arms, new track arm
build thread
build thread
Old 12-31-2020, 10:16 AM   #8
superchevy
Got big-block?
superchevy's Avatar
once the chassis was done, it was time to work on the body....unlike my past builds, I was determined NOT to do any paint work on this build, and only enough bodywork/metalwork to get it driveable....so I left all the rusted holes in place...
build thread
build thread
Old 12-31-2020, 10:18 AM   #9
superchevy
Got big-block?
superchevy's Avatar
cut the floor to install a high hump trans cover
build thread
build thread
Old 12-31-2020, 05:51 PM   #10
buddylee
Hi
Can I ask a favor?
Can you provide the following dimensions
Top of rear frame above axle to floor
Center of axle to floor
Top of tire to floor
Thank you
Looks like a fun project
buddylee is offline   Reply With Quote
Old 12-31-2020, 06:29 PM   #11
superchevy
Got big-block?
superchevy's Avatar
when I get down to the shop this weekend I can take some measurements
build thread
build thread
Old 12-31-2020, 06:34 PM   #12
superchevy
Got big-block?
superchevy's Avatar
I had some custom squarebody buckets and seat frame...cut/welded the seat frame to fit in the factory holes...added an aftermarket console I painted green to match the recovered seat...
build thread
build thread
Old 12-31-2020, 06:44 PM   #13
superchevy
Got big-block?
superchevy's Avatar
I needed to get to work on the bed, but first had to install the LMC rear tank
build thread
build thread
Old 12-31-2020, 06:51 PM   #14
superchevy
Got big-block?
superchevy's Avatar
once the rear fuel tank was installed, I could get to work on the bed...the original wood floor was long gone, so I went to Home Depot and bought some plywood...I ordered some cheap steel bed strips from LMC...because the bed floor is 49" wide, I cut down the two sheets of plywood so they would butt up in the center under the center bed strip...the plywood is soft, so when you tighten down the bolts, the strips dig into the wood for a tight fit...I then painted the inside of the bed, and then scraped it up a bit and set it out in the rain for a while to rust up some...
build thread
build thread
Old 12-31-2020, 06:53 PM   #15
superchevy
Got big-block?
superchevy's Avatar
more bed pics
build thread
build thread
Old 12-31-2020, 07:00 PM   #16
superchevy
Got big-block?
superchevy's Avatar
while the bed was out in the weather to get rusty, I moved to the front to get everything installed...I had a nice 496 bb from a previous build and a stout T400 from another build...got a new TCI 2800 converter and put them together and into the engine bay
build thread
build thread
Old 12-31-2020, 07:07 PM   #17
superchevy
Got big-block?
superchevy's Avatar
because I was going to be running this tunnel ram, I used some POL engine mounts and moved the engine forward to clear the t-ram at the cowl...this would cause me headaches in the future as the POL mounts sit lower than stock and being so far forward, played hell with header fitment, ps pump fitment, fan shroud fitment, etc
build thread
build thread
Old 12-31-2020, 07:53 PM   #18
superchevy
Got big-block?
superchevy's Avatar
with the engine/trans in place I was able to get the front clip reinstalled and the new Torque Thrust wheels came in and got those on...
build thread
build thread
Old 12-31-2020, 07:56 PM   #19
superchevy
Got big-block?
superchevy's Avatar
time to get the bed on
build thread
build thread
Old 12-31-2020, 08:01 PM   #20
superchevy
Got big-block?
superchevy's Avatar
and she looks like a truck now...
build thread
build thread
Old 12-31-2020, 08:07 PM   #21
superchevy
Got big-block?
superchevy's Avatar
I cut the dealer stepside bumper brackets short to tuck the bumper up close to the body.....starting to look pretty cool
build thread
build thread
Old 12-31-2020, 08:16 PM   #22
superchevy
Got big-block?
superchevy's Avatar
finished up the exterior...installed new windshield...buttoned up the interior with new carpet, new dash pad, added old school gauges to the dash, a cool old tach, a tilt column I had laying around, a Superior 500 steering shell I had hanging on the wall, a B&M Truck ratchet shifter, all new front to back AA wiring harness. All new weather strips..I like it, and Big Daddy Rat thinks he's going to do the shifting...
build thread
build thread
Old 12-31-2020, 08:20 PM   #23
superchevy
Got big-block?
superchevy's Avatar
I can't load videos so here are some random shots....
build thread
build thread
Old 12-31-2020, 08:22 PM   #24
superchevy
Got big-block?
superchevy's Avatar
probably my favorite add to the whole truck...you old guys (like me) zoom in..
build thread
build thread
Old 12-31-2020, 08:28 PM   #25
superchevy
Got big-block?
superchevy's Avatar
I built the 'turd in fall/winter, and the rain kept me from driving it quite a bit, so I decided to take off the tunnel ram and put the hood back on so I could drive it whenever....
build thread
build thread
