12-31-2020, 09:36 PM | #26 |
Proprietor of Dale's Corner
Re: My 58 Brookwood
Looks good, keep making some progress!!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-31-2020, 09:47 PM | #27 |
Re: My 58 Brookwood
oh, we're on it now!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
01-04-2021, 10:09 PM | #28 |
Re: My 58 Brookwood
so today we did the new roller timing chain, LS6 oil pump, and LS7 lifters.
01-05-2021, 10:18 AM | #29 |
Re: My 58 Brookwood
That intake sure is purdy! I just gifted myself the Terminator X Max harness for my LQ4. Pretty ingenious little device. Looking forward to hearing it start up. Let me know if you're in need of some headers. I have some on the side of my garage with no place for them to go so happy to gift them elsewhere. Might work well in a sedan if you add some turbos...
https://warrperformance.com/product/...nless-headers/
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
01-05-2021, 10:26 AM | #30 |
Re: My 58 Brookwood
just ordered headers, but I am always in need of LS headers, if the price is right!
01-28-2021, 09:21 PM | #31 |
Re: My 58 Brookwood
so about 3pm we switched over to the 58. this is the new Melling LS6 oil pump. then we put an LS1 windage tray, and a 98-00 Camaro pan and pickup on it.
01-28-2021, 09:28 PM | #32 |
Re: My 58 Brookwood
we noticed that some of the lifters were much longer than others (DOD), so I ordered new LS7 lifters and trays. the white stuff is competition cams assembly lube.
02-02-2021, 08:53 PM | #33 |
Re: My 58 Brookwood
Made some progress on the 6.2 today, put the timing cover on and head studs in.
02-11-2021, 11:22 PM | #34 |
Re: My 58 Brookwood
The oil pan bolts and Valve Spring compressor finally came in, now I can install my LS6 Valve springs!
02-12-2021, 04:46 PM | #35 |
Re: My 58 Brookwood
That level of engine work is beyond me. Very impressive though. How do you know if you missed a part?
02-12-2021, 07:24 PM | #36 |
Re: My 58 Brookwood
I just do, I’ve been doing this quite a while. I just know what goes where.
02-24-2021, 12:23 AM | #37 |
Re: My 58 Brookwood
I know it’s not much, billet oil cooler blockoff. We’re waiting for the new valve spring compressor, the one I ordered the first time sucked!
02-27-2021, 12:35 AM | #38 |
Re: My 58 Brookwood
our new valve spring compressor came in today. This design works WAY better than the old one! #1 LS6 video springs installed!
02-27-2021, 11:31 AM | #39 |
Re: My 58 Brookwood
Love the 58 year and what you are doing with the ole girl.
02-27-2021, 12:32 PM | #40 |
Re: My 58 Brookwood
Thanks 58 is my favorite year as well.
02-28-2021, 12:30 AM | #41 |
Re: My 58 Brookwood
I finally got all the valve springs in one head, These are the good 823 castings with 2.165 intake valves, rectangle intake ports, and D shaped exhaust ports.
03-01-2021, 11:06 PM | #42 |
Re: My 58 Brookwood
we got the valve springs replaced and the heads on
03-08-2021, 11:25 PM | #43 |
Re: My 58 Brookwood
1. New head gaskets came in yesterday, so we put the heads on. Put the headers on and pushrods in. Even started putting the rockers on.
2. I bought billet 1.7:1 roller tipped rockers that are stamped LS3 3. The front of the motor
03-10-2021, 12:17 AM | #44 |
Re: My 58 Brookwood
we got the driver’s bank of adjustable roller rockers in
03-10-2021, 11:10 PM | #45 |
Re: My 58 Brookwood
1. all the roller rockers are installed
2. we mocked up the Valve covers and intake
03-18-2021, 10:13 PM | #46 |
Re: My 58 Brookwood
we put the new ITC billet alt/pwr steering bracket and a brand new water pump.
03-23-2021, 10:22 PM | #47 |
Re: My 58 Brookwood
we got most of the accessories on the LS3 today, tomorrow we’ll put on the per steering pulley and the belt.
03-25-2021, 10:42 PM | #48 |
Re: My 58 Brookwood
We put the pwr steering pulley on
And then started putting together the intake
03-26-2021, 09:39 PM | #49 |
Re: My 58 Brookwood
1. Wyatt decapping injectors
2. This is a decapped injector next to a stock one. We are using dephi Truck injectors with the proper adapters. Decapped they flow 80lb/hr! 3. we installed the new 102mm electronic throttle body. We also discovered that the upper outlet on our 04 Silverado water pump interferes with the electric throttle body 4. a 2010 Escalade water pump was ordered
03-27-2021, 10:12 PM | #50 |
Re: My 58 Brookwood
we got the fuel rails finished today
