Old 10-15-2021, 02:51 PM   #1
Tug87
Weather seals and rubber 71 Suburban
Hi All,
My 71 is at paint right now and I'm doing my best to collect all the weather seals, door bumpers, and rubber for it. I'm hoping to be able to get most if not all to completely refresh the truck.
I have yet to find a complete package so I've been piecing it together as I go. Below is my current list. I'm sure I'm missing a lot as there aren't many category items for Suburban.
Would you please let me know if you see anything that I'm missing and point me in the right direction?
Here is my current list:
Brothers Trucks:
DFSS03D 1967-72 CHEVY/GMC TRUCK DOOR WEATHERSEAL - SUBURBAN/ PANEL SUBURBAN 1 $58.99
SSW6772 1967-72 CHEVY/GMC SUBURBAN SIDE WINDOW SEALS REAR SIDE WINDOW PAIR 1 $311.99
SCDG072 1960-72 CHEVY/GMC SUBURBAN DOOR HINGE GROMMETS GROMMETS 1 $34.99
W172DLX 1971-72 CHEVY/GMC TRUCK WINDSHIELD SEAL - DELUXE 1 $36.99
VWW0072 1967-72 CHEVY/GMC TRUCK VENT WINDOW SEAL SET PAIR 1 $43.99
PSK72FS 1971-72 CHEVY/GMC TRUCK FLEETSIDE PAINT SEAL SET 1 $36.45
THank you!
Tug87 is offline   Reply With Quote
Old 10-15-2021, 03:52 PM   #2
Beach-Burban
Beach-Burban's Avatar
Re: Weather seals and rubber 71 Suburban
Originally Posted by Tug87 View Post
Hi All,
Brothers Trucks:
THank you!
Hey Tug...I've been collecting this kind of stuff to provide to the resto shop when that time comes for me, but you sound like you will be doing much of the work yourself (good for you!). My '72 needs everything rubber as it had lived it's entire life in the hot desert of Lancaster CA...so it's hard for me to tell you what you are missing, however, I found that GMC Paul's online catalog makes it easy to find nearly everything Suburban related. They are one of the vendors that belongs to our "truck family", so I would suggest you look at their website and take your time scrolling through all the pages...you never know what will catch your eye! It was also an education for me, as my list of collected parts continued to grow!!! Good luck with how ever you proceed...and I'm sure some others will weigh in on your post!
Woody
Beach-Burban is offline   Reply With Quote
Old 10-15-2021, 04:20 PM   #3
Beach-Burban
Brothers Trucks:
THank you!
Hey again Tug...Since you asked...Here is my current list:
Seals and other rubber replacement items
(4) Hood, Side Bumpers #30-1821 (?)
(8) Door, Jam Bumpers #BMP 033-4 (Precision)
(2) Rear Side Windows (large stationary) seals #70-1265-81 (Steele Rubber Products)
(1) Rear Hatch Lower Seal #38-6205 (Precision)
(1) Rear Hatch Upper Seal #38-6204 (67-704230 Counterpart Automotive)
(1) Rear Hatch Glass Weatherstrip with Lock Bead #01-319 (?)
(2) Rear Hatch Hinge Grommet #7034 (?)
(4) Tailgate Rubber Bumpers #11-395 (Steele Rubber Products)
(2) Stationary Door Glass Seals #38-6200 (Precision)
(1) Vent Window Weatherstrip Set and Repair Kit #VWK111067 (Precision)
(1) Windshield Weatherstrip (for use with SS trim) #49-8075 (Precision)
(1) RH Rear Door Seal #38-6201 (Precision)
(1) RH Front Door Seal #38-6199 (? G3005)
(1) LH Front Door Seal #38-6198 (? G3004)
(2) Front Door Window Seals #49-8762 (Precision…part of GMC Paul’s 8 pc kit #WFK111367)
(2) Rear Door Window Seals #49-8763 (Precision…part of GMC Paul’s 8 pc kit #WFK112167)
(1) Front Window Anti-Rattle 4 pc kit #WFK????67C (Precision…part of GMC Paul’s kit #WFK111367)
(1) Rear Window Anti-Rattle 4 pc kit #WFK112067C (Precision…part of GMC Paul’s kit #WFK112167)
(2) Front Window Division Bar Felt #111160 (Precision…part of GMC Paul’s kit #WFK111367)
(2) Rear Window Division Bar Felt #111160 (Precision…part of GMC Paul’s kit #WFK112167)
(4) Door Glass Stop Bumpers #AU-4280 (?)
(2) Red Tail Light Lens #67-13450-SB (Counterpart Automotive)
(2) Tail Light Lens Gasket #67-13460-F (Counterpart Automotive)
(2) Clear Backup Lens #EF-2484 (TriPlus Automotive)
(2) Backup Lens Gasket #ST-292 (?)
(2) Backup Housing Gasket #ST-293 (?)
(4) Side Marker Lamp Lens Gaskets #51-511 (?)
(2) Kick Panel Door Vent Seal #411-67 (?)
(1) Firewall Clutch Rod Cover Plate with Gasket #67-7515 (Counterpart Automotive)
(2) Fuse Block Firewall Gasket #ST-250 (?)
(1) A/C Inlet/Outlet Grommet #10-005 (?)
(1) Wiper Motor Rubber Seal #10-018 (?)
(1) Grommet/Retainer Kit #GMCP/CHBGK (?)... Kit includes: 1-windshield washer 3 hole grommet, 2-windshield washer hose single hose grommets, 1-oil pressure line grommet, 1-speedometer cable grommet, 1-emergency brake cable grommet, and 7-rubber firewall insulation pad retainers
(1) Steering Column to Dash Seal #67-3513 (Counterpart Automotive)
(1) Steering Column to Firewall Seal #76-35194 (Counterpart Automotive)
(1) Power Booster Boot Seal #MBM7 (?)
(1) Master Cylinder Boot Seal #10-010 (?)
(1) Gas Tank Filler Neck Grommet #19723976 (?)
(35) Plastic Interior Plugs #11749 (?)
I tried to include who the manufacturer is (as that makes a difference to a lot of people), but that wasn't always available on some items, so I inserted (?). Most all of this came from GMC Paul's...but I found some pieces they didn't have by searching the internet once I figured out what the piece was actually called!
Woody
Old 10-15-2021, 09:01 PM   #4
pwdcougar
pwdcougar's Avatar
Woody
Holy crap Woody! That's a heck of a list!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 10-15-2021, 09:14 PM   #5
HO455
HO455's Avatar
I have heard that the 35 round Plastic Interior Plugs #11749 are no longer available. And the oval ones on the door pillar have not been available since the GM stock ran out decades ago. Be very careful if you have to remove any of them.
I sourced replacement body mount bushings from Classic Heartbeat for my Burban.
You might enjoy looking at the first 5 or so pages of the WMB thread below where I posted some of the trials and tribulations I experienced with mine during the paint part of the project.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 10-15-2021, 09:34 PM   #6
Beach-Burban
Paul
Ha...I know, Paul...and that's just the seals and rubber items! Not that I've had my body & paint guy start yet, but one of the first things he asked was "do you have new...this and that, etc?"...and he was kind of impressed when I said "yes I do!" That's why I made a hard copy of the list.
Woody
Old 10-18-2021, 07:41 AM   #7
Tug87
Woody
Just placed a large order with GMC Paul. Thank you for the recommendation! I really like the no BS format of the site.
Old 10-18-2021, 11:02 AM   #8
Beach-Burban
Glad to hear that it worked well for you, Tug...it does make it easy to "run up the bill", doesn't it! Looking forward to seeing some pictures when you get the Burb back from paint...and follow-up progress as well! Maybe I will get a little more motivated myself, but right now, I'm hesitant to stop driving mine!
Woody
Old 10-21-2021, 09:27 AM   #9
Franks 72
Active Member
Franks 72's Avatar
I did the same total rubber replacement on my 71 (barn door). The only suprise i got was with barn door hinge seals.For some reason when the doors were installed there was not enough room between the hinge bracket and the body. Not sure if that was because the aftermarket parts are thicker than original part. If I would have discovered this before paint I could have widened the hinge clearance passage hole. The other mistake was not installing the gasket onto the hinge arm before shimming and fitment of the door. It is a pain to remove hinge and correct the error now so I had to split the gasket to fit it.
I will probably cut the lip from the rubber seal and attach it with good quality sealant. Our burb never sees rain so seal is not a big issue
Hope this helps.
Franks 72 is offline   Reply With Quote
Old 10-21-2021, 03:03 PM   #10
HO455
HO455's Avatar
I am pretty sure the lift gate and barn door hinge seals are the same. I too was not satisfied with the fit of them compared to the original factory seals. If I could go back I would reuse the originals.
RIP Bob Parks.
